Limp mode!?
Old Jul 23, 2010 | 03:55 PM
CRuNCHyEM1's Avatar
Post Limp mode!?
I get to like 5800 at 5lbs of boost I hit a rev limit.anywhere below 5800 car runs great.
Setup:
B16a block JE8.0:1 pistons
Eagle rods arp studs
Stock GSR head
57trim Garret .50ar
Walboro 255 750cc injectors
Phearable.net base map for now
Stock map! My GM map is ordered I think that's my problem
Old Jul 23, 2010 | 07:40 PM
CRuNCHyEM1's Avatar
Default Re: Limp mode!?
Can someone please help
Old Jul 23, 2010 | 08:00 PM
cevax's Avatar
Most likely its your map sensor, but if you are running on a basemap maybe the limp is a good thing. You don't want to over do it on a basemap
Any more info on the ecu?
Old Jul 23, 2010 | 08:26 PM
CRuNCHyEM1's Avatar
P28 with phearable.Net chip. Once I get my gm map il see what happenes I'm running with a 38mm tail with a .7bar spring so hopfully it goes away but by next week il have s300 with boost solenoid an take it to my local tunner
Old Jul 23, 2010 | 08:31 PM
hybrdthry911's Avatar
did you tell phearable that you had the gm 3 bar or that you had the stock map sensor?
the map is calibrated for only one map sensor you cant just swap whenever you want. they probly put a 5psi boost cut on there because it is just that a basemap, you shouldnt be out there beating on that car UNTUNED.
Old Jul 23, 2010 | 08:37 PM
CRuNCHyEM1's Avatar
Alright well I'm just gonna wait til I get s300 n get it tuned
viper_boy403
Engine Management and Tuning
Oct 30, 2011 07:30 AM
hatchBK4life
Feb 3, 2010 12:08 PM
daflagger
Nov 4, 2007 08:31 PM
rdssk8rcs1
Oct 10, 2006 06:43 AM
See Are X
Oct 13, 2005 04:10 PM
