problems with pcv
Old Jul 10, 2010 | 12:43 PM
wreckeddc4's Avatar
Default problems with pcv
i have a ls vtec turbo setup. im getting problems now even at idle where it almost has the choo-choo train effect from the breather on the valve cover. to add to that problem im pushing oil past my seals on the cams near the timing gears.... anybody have any helpful info for any solutions?
if more info is needed ask me more questions im trying to resolve this asap.
stock jdm b16 head never ripped apart with a usdm stock b18b1 and a 57trim with 12psi...
Old Jul 10, 2010 | 12:57 PM
wreckeddc4's Avatar
Default Re: problems with pcv
bump.... im sure someone knows... ive already been kinda tuned and ran a 12.8 at 118 im trying to resolve this and maybe post faster
Old Jul 11, 2010 | 09:43 AM
tasco's Avatar
are you running the stock pcv system?
Old Jul 11, 2010 | 02:53 PM
jetspeedz's Avatar
Use a catch can, i made my own but T1 and others sell kits. Check those seals as well, overtime if they have not been replaced they will leak, they are cheap but takes time to replace them.
Old Jul 11, 2010 | 04:51 PM
wantboost's Avatar
Who is Mr Robot?
choo-choo effect = shot rings
Old Jul 11, 2010 | 04:55 PM
wreckeddc4's Avatar
ok thanks guys... ill try a few more things and see what comes of it
Old Jul 11, 2010 | 05:20 PM
wantboost's Avatar
Who is Mr Robot?
in your other thread, I posted some stuff. I assume you're doing a compression test... When you do, do it normally the first time. Do it a second time but add oil to the cylinders right before you do it. The difference between the two will give you an idea of how far gone the rings are
Old Jul 11, 2010 | 08:08 PM
wreckeddc4's Avatar
the other post was by my roommate i didnt know he posted. i REALLY dont think its my rings but im a full time student and i work full time so itll happen in the next few days. ill let you know on the results
Old Jul 11, 2010 | 09:57 PM
wantboost's Avatar
Who is Mr Robot?
if its smoking out of the breather, thats pretty much the only thing it can be
Old Jul 12, 2010 | 06:58 AM
wreckeddc4's Avatar
im trying to stay positive haha!
Old Jul 12, 2010 | 01:36 PM
wreckeddc4's Avatar
verdict is... cyl 1 70psi, cyl 2 180psi, cyl 3 70psi, cyl 4 210psi
Old Jul 12, 2010 | 01:51 PM
wantboost's Avatar
Who is Mr Robot?
cylinder 3 is definitely the problem.
its a good excuse for a built bottom end :p
what you can try in the mean time is some of that lucas engine restore stuff (or whoever makes it) it works decently at fixing problems like yours, wont last forever but it'll work long enough till you can do something about the bottom end
Old Jul 12, 2010 | 05:42 PM
wreckeddc4's Avatar
im grabbing a gsr long block from a friend and im still going to run it like its a ls vtec setup but its a fresh build. i figure all my charge pipe is cut for the b16 and the golden eagle sandwich plate feeds my turbo sooooo..... poor mans type r basically and ill build the head over the winter and probably do a piston rod setup anyways. i really appreciate the help tho it just sucks... im not even mad tho i had the ls block for almost 6 years and ran it lsvtec for 3 years. the gsr will bump the compression a tad so i can run less boost for the same power and it has a main girdle so there is a plus to this
Old Jul 12, 2010 | 06:07 PM
wantboost's Avatar
Who is Mr Robot?
yep, you cant really argue when you've gotten 6 years out of a stock block, it had to give up sometime
Old Jul 13, 2010 | 08:13 PM
wreckeddc4's Avatar
agreed. its not like its horrible hoirrble. itll probably get rebuild with stock parts to go into my winter/DD
josephcmiller2
May 11, 2011 07:58 PM
wreckeddc4
Jul 11, 2010 04:35 PM
93 EG
15
Sep 22, 2008 09:46 PM
quaker
Sep 27, 2007 09:25 PM
mikeaitken
Apr 23, 2007 10:17 AM
