turbo housing?
Old Jul 7, 2010 | 10:02 PM
young geezer's Avatar
Default turbo housing?
so i have a garrett t3 t4 turbo and it went bad and i got a new one but the new one has a 4 bolt down pipe and my other one is 5 bolt down pipe. but both are .63 on the exhaust side and .60 on the cool side. so i was wondering if it is interchangeable bymyself or do i need to take it to professional?
Old Jul 8, 2010 | 06:49 AM
TheShodan's Avatar
Moderator
Default Re: turbo housing?
If its the standard 50,57,60 trim series with the the stage III wheel (2.559" wheel diameter on the turbine side), then it is possible as long as the other housing is the same. But remember this, newer ones are almost $200. You can try and find a used one, but many people are not separating turbocharger components. Best bet is to cut that flange and have a 4 bolt weld flange ($23) welded instead.
Old Jul 8, 2010 | 03:26 PM
turbohatch96y7's Avatar
Well he already has them both. To take off the housings just un bolt the backside of the turbo there should be like six bolts. Take them all out and the housings should just slide off.
JrCRXHF
Jun 15, 2005 06:27 PM
StolenTeg
Jan 20, 2005 12:45 PM
JD95hatch
Oct 14, 2004 01:23 PM
