2 step (launch control) settings
Old Jul 21, 2010 | 01:55 PM
E85B18's Avatar
Default 2 step (launch control) settings
I've searched H-T for 2 hours and have not found what I'm looking for. I'm wondering what are the "safe" limits for timing and fuel? I've seen people run up to -40 degrees and +400 units of fuel. This is on a sleeved 500whp DC2 running E85 and an s300.
RPM?
Timing Advance (Retard)?
Fuel added?
Boost result?
Thanks
Old Jul 21, 2010 | 02:13 PM
projectcivicjp's Avatar
Default Re: 2 step (launch control) settings
In order to find this out the SAFE way you need to have the car properly tuned by a competent tuner. Its all a matter of what the motor/setup likes and doesnt like. Then you will be able to configure your 2 step.
Old Jul 22, 2010 | 07:55 AM
E85B18's Avatar
The car is properly tuned. The tuner set the two step but Im not building enough boost. I don't believe there's one spot you should have the car set at, there's a range depending on the tires you're running and how much boost you want to build. People adjust their two steps all the time. But... I would think -40 degrees is too much on all set ups
Old Jul 22, 2010 | 08:27 AM
kte324's Avatar
I would also like to know. I believe I am set at like -30 degrees and +100. I building around 10psi.
Old Jul 22, 2010 | 10:30 AM
Oh ok! I know what you are trying to do now! I would pm Tony from T1, Miller from NYC, or one of those guys and ask their opinion. I know you can data-log and trend your boost level while cutting ignition gradually.
Old Jul 22, 2010 | 03:21 PM
damndan23's Avatar
im at -15 and 300 fuel enrichment making 14lbs. keep in mind the more timing you pull the more boost you will make. best bet is starting your limiter at say 6500 the other at 6700, -5 and 200 fuel if thats not enough boost go to -10 and 200Fuel. changing rpm will alter the boost level aswell. every set-up is different so start out low and work from there.
EL TYPE R
Mar 7, 2013 09:33 AM
v8killaz
Sep 9, 2012 03:00 PM
nvmyb20hatch
May 24, 2006 04:53 PM
94ta_lt1
Dec 25, 2004 03:45 PM
dirtySOHC's
Jun 21, 2003 11:00 PM
