HELP Clocking a Turbo
Old Jul 27, 2010 | 07:46 PM
DeyAinRdy4Ds's Avatar
Default HELP Clocking a Turbo
sup guys..im trying to clock my turbo...i followed all instructions on loosening the 6 bolts on both sides, but now it just wont turn...doesnt budge at all and all bolts are definitely loosened enough.....the turbo is on right now and id rather leave it on, but i may have no choice to remove it and try clocking it then....
but any suggestions on making this damn thing turn....anyone run into a similar problem?
Old Jul 28, 2010 | 06:15 AM
HarfordCTR's Avatar
Default Re: HELP Clocking a Turbo
Rubber mallet, gotta break it loose sometimes.
Old Jul 28, 2010 | 06:22 AM
OpusGarage's Avatar
Yeah, but don`t hit a impellers, only housing..
Old Jul 28, 2010 | 06:30 AM
i was trying a hammer with a wooden block in between but i dont think it even budged? do they cease up that much sometimes?
i was trying to hit the oil feed part since thats the only part thats sticking out....
heres pics if they help
Old Jul 28, 2010 | 07:29 AM
TheShodan's Avatar
Moderator
STOP STOP STOP STOP!!!! The bolt your pointing to attaches the backplate to the cartridge. Tighten that back up RIGHT NOW!!!
Only loosen the bolts that attach the compressor cover (the ones that are up against the brackets that hold the compressor cover to the backplate.
At most, you may need to loosen the bolts connected to the turbine housing (also has two brackets). Those are the ones that are difficult to move. but only if necessary.
STOP!!! Put that backplate bolt back in.
Old Jul 28, 2010 | 04:29 PM
ok ya i was advised that i dont need to loosen the ones i was pointing to....but it wasnt moving with all the other loosened ..thas y i sent that pic to sum1 asking if i need to remove those that im pointing to...but i guess thats a negative...
which other bolts are you talking about? i loosened the 6 + 6
DeyAinRdy4Ds
Jul 27, 2010 02:08 PM
patrick4588
Jun 29, 2007 09:33 PM
elpiar
Jun 14, 2005 03:11 PM
Dawson21
Jun 5, 2004 09:08 AM
B18C-RnVA
Sep 15, 2002 06:59 PM
