Garrett GT3271 Turbo B16A2 too big?
Ok, so I got an awesome deal on a GT3271 turbo. Is this turbo going to spool on my b16 civic si? I am going to start with 9psi, and eventually when I build the engine some, turn the boost up. ANYONE run this turbo? I searched HT for this turbo and came up with this...
http://www.ht-archive.net/showthread.php?t=1141473
THE SHODAN says it is a good b16 turbo. However, Im not sure if the GT32e has similar specs to the GT3271.
Also,
https://honda-tech.com/forums/forced-induction-16/borg-warner-vs-garrett-turbos-2369852/
Again, the GT3271 appears to be compared to a T3/T04E "50 trim", which I was previously looking at putting on my car.
Here is the link to Garrett with the specs for this turbo.
http://www.turbobygarrett.com/turbob...1_452203_1.htm
Also,
Moderator
Re: Garrett GT3271 Turbo B16A2 too big?
Oh yeah, I remember those 71mm. I changed housings when I used to put those together as the way the come in the box was kind of a pain. Out of the Box, you have a 6 bolt flange (weird) that almost no one has for a downpipe flange. Its nice that its internally gated, but you need to have a manifold that will support that. Otherwise, its a fun unit.
the 6 bolt flange shouldnt be a problem. i had a few patterns (got dimensions from garrett.com) torched out at work on 1/4 inch T-1 steel. Ill just have to weld my downpipe onto it. The exhaust flange has a 60mm ID. Can I weld on a 3" DP or should I stick with a 2.5"?
