Sleeve thickness?
Old Jul 25, 2010 | 08:04 PM
DCtooD's Avatar
Default Sleeve thickness?
Does anyone know how thin the sleeves can be before cracking? I obtained a gsr block for free with unknown steel sleeves that is bored out to 83mm and the sleeve thickness is 5.7mm but plan on boring it to 83.5. The setup will not make anymore than 550whp. Just wondering if it will handle that power.
Old Jul 26, 2010 | 08:06 AM
E85B18's Avatar
Default Re: Sleeve thickness?
With a resleeved block you can go to 84.5, a few people run 85 but most don't recommend it. I'd try to determine what sleeves you have before you put time and money into it.
Old Jul 26, 2010 | 08:23 AM
boostedeg302's Avatar
If you recieved the block for free, chances are that it is stock sleeves. If this is the case, I would personally not go any thicker than 81.5mm with a boosted setup as it will not be safe with that thin of a sleeve. If the block has aftermarket sleeves (ie. golden eagle, darton, etc), you should not go any further than an 84mm bore. Sleeves will crack no matter how thick they are if the tune is not up to par. Post up some pictures of the block and I will tell you if it has stock sleeves or aftermarket sleeves. Hope this helps
Old Jul 26, 2010 | 08:51 AM
DCtooD's Avatar
I am sure that it isn't stock sleeves for they are all steel and not 1 piece. It seems that it's an old sleeve design or something and looks thin compared to today's sleeves. I will get some pics up later today. Thanks for your replys.
Old Jul 26, 2010 | 09:04 AM
E85B18's Avatar
If they're aftermarket 83.5 should not be an issue. Post some pics, they will help
Old Jul 26, 2010 | 07:41 PM
DCtooD's Avatar
Got some pics. Looks like it's o-ringed too. Let me know what you guys think.
Old Jul 27, 2010 | 07:44 AM
jetspeedz's Avatar
Up to 84 should be fine for boost i would not got straight to 84mm however keep it is small as possible in case you want to throw in some new pistons you can always go .5mm bigger and not worry. good luck
Old Jul 27, 2010 | 08:52 AM
DCtooD's Avatar
My concern is that they seem to have been the same thickness as stock sleeves but bored out to 83mm. So because these are steel, are they going to be strong enough knowing that they are that thin?
Old Jul 27, 2010 | 12:06 PM
Im not feeling to well today but those look like stock sleeves to me....
Old Jul 27, 2010 | 12:07 PM
1 piece sleeves are not stock. Two piece, like the ones pictured, are stock
Old Jul 27, 2010 | 01:15 PM
DCtooD's Avatar
I never seen a stock block with steel sleeves. Liner yes but not the sleeve. I'm guessing you're looking at the copper o ring.
Old Jul 27, 2010 | 02:21 PM
ashb82's Avatar
That looks like a benson or la sleeved block. Good free find you have to be so lucky
Old Jul 27, 2010 | 02:35 PM
cruizinmax's Avatar
stock sleeves are not divided between each cylinder though are they?
Old Jul 27, 2010 | 02:44 PM
E85B18's Avatar
Not sure but aren't la sleeves one piece? Like these... Plus they look thicker...
Old Jul 27, 2010 | 03:06 PM
^Im pretty sure benson sleeves look similar to that as well. If it were sleeved by benson, it would be stamped by them as well
Old Jul 27, 2010 | 03:08 PM
No they are not. Im stumped on this one. Those are some pretty thin sleeves if they are aftermarket
Old Jul 27, 2010 | 05:17 PM
DCtooD's Avatar
If my memory serves me right, the block was probably sleeved by benson for the shop locally which it originally came from (which is now shut down) used only benson but this was back in 2000-2002. So I'm guessing that I shouldn't run it then?
Old Jul 27, 2010 | 06:00 PM
ashb82's Avatar
[QUOTE=E85B18;43142952]Not sure but aren't la sleeves one piece? Like these... Plus they look thicker...
QUOTE]
no here is what la sleeves look like the one you pictured seems to have been welded
Old Jul 28, 2010 | 08:13 AM
E85B18's Avatar
Thanks. That's a better picture than mine. For some reason the dumb *** shop that sleeved my block welded in some sort of block guard crap. But.... I believe they're la sleeves inside (even tho they sold me golden eagle). F**king shops in this industry...
Old Jul 28, 2010 | 03:55 PM
cruizinmax's Avatar
Are you for sure you have a 83mm bore? Here is a pic of a 84mm bore and the thickness of the sleeves between the cylinders the same or greater than yours. Nevermind the arrow. I stole the pic from google. lol
Old Jul 28, 2010 | 05:29 PM
ashb82's Avatar
btw your block may just need to be honed to remove the surface rust. the sleeves dont look that bad
Old Jul 28, 2010 | 07:43 PM
DCtooD's Avatar
Yes I am sure it is 83mm. Maybe it just looks thinner on mine cause there is a gap inbetween the cylinders.
I think so too. We'll see what the machine shop says.
12secdc2
Dec 4, 2008 09:25 PM
Boostn B20
Aug 20, 2008 03:28 PM
lsgsrhatch23
Jun 20, 2006 07:05 PM
hbvetteslayer
Jun 26, 2003 08:56 PM
satan_srv
Mar 19, 2003 01:52 PM
