oil pump!
Old Jul 23, 2010 | 12:07 PM
88 EF Hatch's Avatar
Default oil pump!
So I have a gsr block with no oil pump. I have a b16 oil pump at home, and I was wondering if it will work on the gsr block. I know it will bolt up, but I need to know, does it put out the same work a gsr oil pump does? and I i run a b16 oil pump, will i also need to run a b16 water pump. Reason I ask is last time when I mated an ls fpr on a b16, it created problems and car ran like crap, b/c fuel pressure specs on the ls fpr were different than the b16 fpr. SO do want to run into a problem later down the road
Old Jul 23, 2010 | 12:10 PM
boostedeg302's Avatar
Default Re: oil pump!
you will be fine. all oil pumps are interchangable as long as they are b series.
Old Jul 23, 2010 | 07:01 PM
ok
Old Jul 23, 2010 | 07:28 PM
well i found a gsr oil pump. Is there a difference between the b16 oil pick up and gsr oil pick up?
Old Jul 24, 2010 | 05:05 PM
TheShodan's Avatar
Moderator
Just get a nice new oil pick up for good insurance based upon the block you have. It's just a couple of bucks..
Old Jul 25, 2010 | 10:58 AM
ok koo, so that gsr pump, never came thru, so original question is open
sepulchral
Jun 8, 2006 12:01 AM
