another coolant line question
Old Jul 6, 2010 | 06:53 PM
slammedobd1teg's Avatar
Default another coolant line question
can you feed and return both to the radiator?
i want to feed it off the bottom of the rad and return it to the top.
i am having some slight overheating issues and i figured it would be best if the hot coolant from the turbo doesnt ever even go to the motor. if its possible i would like to both feed and return directly to the radiator with weld on fittings.
Old Jul 7, 2010 | 05:57 AM
EsotericImage's Avatar
Retired Moderator
Default Re: another coolant line question
i would look to a radiator that has coolant lines in place already. Problem solved.
Also, down here in florida wheres its hot as hell, My 12" fan couldnt hold up to the heat, so i found a 13" mardyne from Xenocron.com which pulls 1300 cfm and its doing a great job of keeping it cool.
Old Jul 7, 2010 | 10:08 AM
Muckman's Avatar
Moderator in Chief
No, it wouldnt work very well.
Old Jul 7, 2010 | 06:18 PM
care to elaborate?
just to make sure im clear im talking about coolant lines for a ball bearing turbo. feeding it from the bottom of the rad, and returning it to the top.
Old Jul 8, 2010 | 07:31 AM
xenocron's Avatar
I have seen people feed and return to the bottom and top of the radiator a lot...the turbo doesnt NEED a whole lot of flow through it, and the fluid transfer would happen enough because of temperature differential.
codenamezero
Mar 23, 2012 02:51 PM
Hemix
Feb 5, 2010 01:30 PM
b20forlife
May 14, 2009 05:11 AM
.adam.
Nov 30, 2007 08:06 AM
96WhiteOnBlack
Apr 5, 2007 08:01 AM
