ls/vtec turbo HELP!!!
Old Jul 23, 2010 | 11:19 AM
kbear's Avatar
Default ls/vtec turbo HELP!!!
i just decided to go ls/vtec turbo instead of ls turbo and was wondering if i could use the cp pistons that were ment for a stock ls head or not. im wanting to get a mild build on the stock ls block and a friend of mine is selling a set of cp pistons and eagle rods but they are for a ls block with ls head. my question is would that change the CR enough to where it would hurt me and slow me down since im using a vtec head or would it not matter? he is selling them to me for a pretty good price so i was wondering if i should get them or not. does it matter?
oh here the compressionon the cp pistons for the ls long block is 9:1
if i put on a b16 head will it raise the compression to 10?
cliff note:
are cp pistons that were ment for a ls long block ok to use in a ls/vtec build? would it raise the compression from 9:1 to ten
Old Jul 23, 2010 | 05:24 PM
kbear's Avatar
Default Re: ls/vtec turbo HELP!!!
anyone?
Old Jul 23, 2010 | 09:44 PM
LS_VTECteggy's Avatar
lower compression if you do ls/vtec and the pistons should be ok no matter the head...
Old Jul 24, 2010 | 10:32 PM
kbear's Avatar
ohh...so it would lower the compression from 9:1 to what if i am already using 9:1 cp pistons for ls long block
Old Jul 24, 2010 | 10:42 PM
I'm not sure by how much but assuming your using the stock pistons I remember reading which you should be doing too... that when doing an ls/vtec your compression is reduced
Old Jul 25, 2010 | 12:24 PM
kbear's Avatar
hmmmm well either way it the compression should stay within the 9-8 right?
Old Jul 25, 2010 | 04:16 PM
boostedeg302's Avatar
You will be fine using those pistons. It will raise the compression ratio but not by a whole lot. You will be around 10:1 give or take which is still fine for a turbo engine.
Old Jul 26, 2010 | 06:47 AM
bOoStEd_180e's Avatar
the combustion chamber difference between the ls head and the b16 head is 2.3cc which isnt gana up the compression by 1 point...itl be around 9.3:1 which is perfect for turbo application
Old Jul 26, 2010 | 07:43 PM
kbear's Avatar
nicee lol now...what bearings to use? acl? or oem...
Old Jul 29, 2010 | 07:31 AM
i say go oem...acl are 1 size bearings so you gana have to have the crank cut
silverdc2integra
Sep 28, 2009 11:17 AM
TougeCoupe
May 29, 2005 05:58 PM
2 point 0
Apr 22, 2004 03:11 PM
Kingsperformance
Feb 25, 2004 02:16 PM
tfalconier
Nov 26, 2003 09:16 AM
