Greddy 18G....*sigh*...a little help please.
Alright folks, I have a Greddy 18g kit for a GSR...I got the kit from a friend and he did not include the fitting that goes inside the turbo for the oil feed line.
Could someone tell me if this is exactly what I need? I really have done research and can't find an exact answer. I've went to my local hardware stores and even an hour away and I cannot find something that is not ghetto that will work.
Will this work for my application?
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_1487wt_939
Thanks for all advice in advance.
Re: Greddy 18G....*sigh*...a little help please.
Take the turbo to a High Performance shop that does stainless braided hose, for sure they should have a fitting that will work.
i would take the turbo to a hardware store and test fit some different sizes. im almost positive that its m10 x 1.25 but it could be m10 x 1.5 or m12 x 1.5, once you figure out the correct size you can grab the correct banjo bolt online or something
PS, the fitting you posted has a built-in restrictor already, might want to double check with greddy to see if their turbos even require a restrictor. also a -3an might be better suited for that turbo
last time I ran 18g I don't think there was a restrictor. I think it was just a banjo bolt coming of a big *** braided line. Maybe not but it has been awhile.
Bailhatch
10-22-2003 07:53 AM
