H22 turbo issue..
Old Jul 17, 2010 | 06:02 AM
tommiboy's Avatar
Default H22 turbo issue..
My car is currently in the shop for tuning. However, the car would only run for about 10-15 minutes and then shut off. Then it won't start for a while. The tuner also said that when he plug in his tuning device that while the car was running, it fried that device. He thinks there is something electrical is wrong with the car but have no idea what could be causing it.
I know it's a long short and the info provided is not much but have anyone have similar issue?
We have tried changing the main relay but it didn't help.
MY setup,
H22
sleeve
sc61 turbo
Old Jul 27, 2010 | 01:00 PM
tommiboy's Avatar
Default Re: H22 turbo issue..
here's a few things we've tried but still no luck. any input would be great.
Adding an 8 gauge ground did not help.
The new main relay did not help.
When the car shuts off it happens all at once like you've turned the key off so there's no time to see if spark stops or fuel stops etc.
When we try to start the car after it shuts off and it won't start, sometimes the fuel pump has no power and sometimes it does. Sometimes the car has spark during cranking and sometimes it does not.
Also, every time we go to work on the car the battery is stone dead and we have to charge it before we can do anything
Old Jul 27, 2010 | 02:50 PM
EK9H22T's Avatar
Wow dude thats wack. Turbo timer?
Old Jul 28, 2010 | 11:24 AM
amsti06's Avatar
Get a new wiring harness
peter17212
10
Feb 8, 2008 04:48 PM
redline7
Jul 16, 2007 08:49 AM
BLKCivicPorscheStyle*
May 11, 2006 06:31 PM
bigbacon2
Sep 17, 2005 03:41 PM
