flex section
Old Jul 13, 2010 | 07:35 AM
slowboy90's Avatar
Default flex section
Who makes a good flowing 3 or 4 in flew section
Old Jul 13, 2010 | 09:52 AM
90Rexx's Avatar
Default Re: flex section
i got mine from ATP turbo. it was cheap, and its high quality. im happy with my purchase
Old Jul 13, 2010 | 12:24 PM
Turbo-LS's Avatar
just be sure its braided inside and not ridges, the ridges are a pretty good hp killer
Old Jul 13, 2010 | 12:56 PM
berb_15's Avatar
Do you have an article or something stating this? I'm not trying to be rude or say you're wrong I'm just interested. I can see where you could get some losses but are they really that big? Let me know if you do. Thanks
Old Jul 13, 2010 | 01:01 PM
slowboy90's Avatar
so 90rexx do you know if the atp is braided inside?
Old Jul 13, 2010 | 01:40 PM
gizzmo222's Avatar
eBay
Old Jul 13, 2010 | 03:34 PM
Runnerdown's Avatar
Actually, the flex sections with mesh inside should be avoided. It is possible they flow better, but I haven't seen any difference on our dyno. What does happen to them sometimes is the mesh will collapse and leave a very small small opening for the exhaust to get through. This does make a noticable difference on the dyno, making about half the power is a normal symptom.
Old Jul 13, 2010 | 06:09 PM
Turbo-LS's Avatar
A friend of mine had a flex on his car with the ridges only and it hit a wall during tuning. the place he was at installed a new flex section one with the braided insie overthe ridges and the car picked up 30whp right off the bat and then was able to continue turning up the boost and not hitting that wall. Seems like a ggod thing to me. i personally hav on with ridges but its been on my car for a long time before i knew this information
Old Jul 13, 2010 | 07:10 PM
Tjabo's Avatar
Is there a really good option, other than no flex at all?
Stupid question, but how far down the exhaust would you have to go to be able to put a high quality, high temp silicone coupler on it?
I'm also thinking of trying something like this:
http://www.streetperformance.com/part/flowmaster/exhaust-flex-joint/1398649-15930.html
Old Jul 13, 2010 | 07:32 PM
wantboost's Avatar
Who is Mr Robot?
just make a slip fit exhaust...
if you run really good motor mounts the flex section isnt needed, its only there to compensate for the motor rocking. I never ran one on my em1 (solid mounts) nor on my 240 (solid mounts) nor on my crossfire (solid mounts)
no problems ever
Old Jul 14, 2010 | 03:42 AM
Tjabo's Avatar
I can't speak for the OP, but in my case with urethane filled mounts (in a Neon) there is still more movement in the drivetrain than I'm comfortable with unless I have a flex SOMETHING in there somewhere. I have the thought of transferring all of that stress to my manifold studs.
Old Jul 14, 2010 | 04:00 AM
wantboost's Avatar
Who is Mr Robot?
I said solids, as in metal... no urethane, no give.
With anything other than solids you need some sort of flex. and a ball joint wont work, thats for misalignment, not front->back movement.
Old Jul 14, 2010 | 06:14 AM
Tjabo's Avatar
Don't tell that to the factory, they seem to find them quite adequate.
Old Jul 14, 2010 | 06:59 AM
slowboy90's Avatar
ok long story short im going to go from a 3 in downpipe to a 4 in exhaust i have filled mounts but it still moves. all flanges will be vband
Old Jul 14, 2010 | 09:23 AM
90Rexx's Avatar
my 3 inch flex from ATP has ribbed inside... i dont see where there would be an issue..... im completely confident in installing it and not losing power.
Old Jul 14, 2010 | 09:50 AM
Tjabo's Avatar
You mean ribbed like a bellows, or convolute or something? That's what mine is like on the inside too, and it sounds like they must create a lot of turbulence that hurts flow. . . or something.
Old Jul 14, 2010 | 09:59 AM
sneakysneaky's Avatar
Mesh is the way to go, but they blow out occasionaly.
I bought mine from vibrant last time.
Old Jul 14, 2010 | 02:35 PM
Turbo-LS's Avatar
just try and put it far back on the dp as possible so it wont blow apart from heat or flame from 2step idk
Mhollaek9
10
Aug 1, 2007 09:42 AM
spotch
Honda Civic (2001 - 2005)
24
May 28, 2007 04:28 PM
Norcalstoppy
Sep 28, 2005 06:48 AM
RZFD
Apr 26, 2005 11:56 AM
nekkedR
Jun 16, 2003 09:53 PM
