6265
Old Jul 24, 2010 | 12:28 PM
v.i.gsr's Avatar
Default 6265
Wanted to know if it is possible to run a precision 6265, with an a/c compatible manifold..
I know there may be a good bit of the block, that would have to be shaved..
If anyone has pulled it off,what housing are you using..
show some pics..
Old Jul 24, 2010 | 12:57 PM
90blackcrx's Avatar
Default Re: 6265
With the proper manifold, yes. With the cast iron type, I don't think so. You'd really have to shave a lot of the block down.
Old Jul 24, 2010 | 01:03 PM
v.i.gsr's Avatar
Default Re: 6265
was thinking about a ramhorn or a mini-ram, with a 3" dp..
Old Jul 24, 2010 | 08:55 PM
runsfromdacops's Avatar
Default Re: 6265
speed factory i wa. has a manifold that will work for the 6265 with a/c. ask for ricky
Old Jul 25, 2010 | 07:02 AM
TheShodan's Avatar
Moderator
Default Re: 6265
The 6265 uses either a T04E or T04S compressor cover, with the same dimensions as Garrett. So whatever exhaust manifold that you have that can fit a Garrett turbocharger of similar size dimensions, and you want to fit a 6265. It is generally more difficult to fit the T04S cover than the T04E, so you may have to make some changes if going for the larger compressor cover.
Now if it were a Borg-Warner with a different cartridge length, this might be a different story.
DC2BUD
Dec 24, 2010 07:02 PM
integlspwr2k
Jan 17, 2008 02:17 AM
ant56
Jul 11, 2007 06:43 AM
crucian
Oct 10, 2006 09:19 AM
crazy_eddy
Jun 11, 2006 05:26 PM
