Over Heating Problem
Old Jul 20, 2010 | 10:23 PM
Blue94Accord's Avatar
Default Over Heating Problem
-built H22 on boost, 94 accord-
I've been over heating while boosting 10psi
Anti-freeze sprays out of the radiator cap.
Want some opinions for what could be the problem.
I figure everyone is going to say get a bigger radiator
-brand new water pump
-2year old thermostat
-stock accord radiator
The car runs fine when im boosting high but shifting before vtec. Overheats when i max out each gear.
It got so hot in cylinder 4 that the spark plug gap melted closed.
opinions?
fans work btw
Old Jul 21, 2010 | 07:34 AM
Tootsie7944's Avatar
Default Re: Over Heating Problem
If it's spraying out of your radiator cap, then your cap isn't working and your system isn't staying pressurized. Pressurizing a coolant system raises the boiling temperature and it sounds like your car is hitting 212 degrees (assuming your just running water) and it's boiling over instead of the excess going into your overflow tank.
Could also be your headgasket maybe isn't sealing and your coolant system is pressurizing (happens to a TON of turbo imports).
I'd go ahead and replace your thermostat and radiator cap since it's cheap and easy.
Old Jul 21, 2010 | 08:04 AM
sanman000719's Avatar
wa shaving the same issue try running the heate all the time, and see if it works better for you
Old Jul 21, 2010 | 08:17 AM
kyden's Avatar
sounds like blown headgasket/head lift.
Old Jul 21, 2010 | 10:23 AM
Golden Eagle head gasket and arp headstuds. Only has 1200miles on them. I don't think the headgasket is blown.
Im using anti-freeze not water.
I was thinking bad cap.
So no one thinks its because to small of a radiator?
Im running like 400+hp
Old Jul 21, 2010 | 10:24 AM
feriojdm's Avatar
I am having a problem with my engine not revving pass 4000 any ideas or solutions... i have a sohc d15b vtec
Old Jul 21, 2010 | 10:27 AM
start your own thread slow guy
What exactly do you mean?
Old Jul 21, 2010 | 11:26 AM
AlexDphoto's Avatar
Running heat all the time full blast allows for your coolant to circulate and lets your temperatures drop. However this isnt a permanent fix to your problem. If I were you, I would check to make sure youre not getting head lift.
What head studs are you using? And what are they torqued to? What Headgasket?
Old Jul 21, 2010 | 11:49 AM
ARP headstuds 3 stage torq to 80tq- re-torqued at 900miles
golden eagle headgasket
all 8 studs were perfect when i did the retorq
Old Jul 21, 2010 | 01:15 PM
so just checked my oil and had a good amount of antifreeze in the oil. SOO looks like my headgasket is bad.
now the questions is what caused it..
-bad radiator cap leaked water cause overheating and killed the gasket
-bad sleeve?
the build setup is darton sleeves, cp low comp piston, pauter rods, skunk2 valves-springs-cams-gears- retainers. 87mm
Old Jul 21, 2010 | 03:28 PM
damm yah you got a head gaket gone man lol
in the summer time i get hot quick and the heater running full blast helps me alot
Old Jul 22, 2010 | 04:39 AM
kyden's Avatar
*cough*
Old Jul 22, 2010 | 05:21 AM
It's not really to do with the small radiator....I have 600 whp and only have a half size radiator and run my AC around town on 95 degree days. Coolant temps get to 220 degrees.
Your radiator cap sounds fried, your headgasket either was blown or wasn't sealing properly.
Pull the head, put a new GE headgasket on, torque your studs...let sit for hour, the loosen and re-torque all at once, and also replace your radiator cap and report back.
Also, you should be running a SPAL 13" HP fan if you have a half size radiator...all other fans are a waste of money.
Old Jul 22, 2010 | 05:44 AM
ashb82's Avatar
I had a head do that one time, i did not resurface it.
Old Jul 22, 2010 | 01:38 PM
Should i spend the extra money again and get another golden eagle gasket or would a nippon racing one work just as good?
I havent had the time to take the head off yet but i should have it done by next week.
So, im thinkink radiator cap was bad and leaked. car overheated and killed the gasket.
bauergold
Jul 9, 2019 07:47 AM
h22a2JZGTE
Feb 25, 2013 07:13 AM
freshgear
Jul 19, 2009 01:48 PM
kjkhemraj
21
Jul 24, 2007 11:54 AM
viperguy
Jun 20, 2003 09:35 AM
