LSvtec ARP head stud torque spec
Old Jul 20, 2010 | 09:38 PM
092eg6's Avatar
Default LSvtec ARP head stud torque spec
hey wassup guys, my friends gonna go turbo in his LSVtec and we put arp head studs in there and torque to 65ft lbs. is that ok? the studs were used once on a different motor, dont kno how much pound was torqued the first time, but what do u guys usually torque yours to or what should i torque it to to not blow the headgasket? please only answer if u have done this before thanks.
Old Jul 21, 2010 | 06:36 AM
EsotericImage's Avatar
Retired Moderator
Default Re: LSvtec ARP head stud torque spec
there is a sequence you need to follow when torquing the studs down.. it can be found with a little searching. check ARP's site.
or find the part # and call them for the specs your looking for.
i think its 80ft/lbs but im using a different set.
Old Jul 21, 2010 | 11:32 AM
AlexDphoto's Avatar
should be torqued to about 80-85 with 30W oil and I believe 65-70 with Moly lube
avotegra
Dec 27, 2015 01:26 PM
Kr4nG
Nov 6, 2009 02:48 AM
gonmaro
Jan 29, 2009 12:05 PM
slo_b18
Jan 30, 2008 08:47 AM
TokuiAutowerks
Oct 12, 2005 09:11 AM
