gt2871r on b16.
Old Jul 24, 2010 | 08:33 PM
s10cky's Avatar
Default gt2871r on b16.
Hey guys,
I am rather inexperienced with forced induction. My current setup is relatively simple. Built 16 bottom end with wiesco's and eagle rods, stock b16 head with gsr cams. It is running an hks log manifold withe gt2871r. I do not see full boost (12 psi) untill 6k. I feel as though this is a bit off. Can anyone chime in as to whether this is normal or what can be done.
The turbo is running internal wastegate with 14lb. spring.
,Matt
Old Jul 25, 2010 | 05:55 AM
s10cky's Avatar
Default Re: gt2871r on b16.
Ive read on a few boards that the actuator my not be functioning properly, and a vacuum leak is another possibility.
Old Jul 25, 2010 | 06:57 AM
TheShodan's Avatar
Moderator
Sounds like some sort of vacuum leak. Check you hoses and lines for any misfitted parts, tears of any kind.
Also check to see if the turbo is ingesting any exhaust gasses. This usually occurs when people don't have the dumptube routed outside of the engine bay far enough. (Pointing "downward" does not help, it must be out of the engine bay completely.
And no, the manifold is fine for the car, and for its purpose is well fitted. No need for "ramhorns" or Topmounts with this setup
Old Jul 25, 2010 | 08:08 AM
92TypeR's Avatar
FSAE
That was my first thought. If the internal wastegate flapper is not seating properly, the turbine will take much longer to spool.
Old Jul 25, 2010 | 09:04 AM
s10cky's Avatar
Is it common to have to replace the Garrett internal wastegate?
Old Jul 25, 2010 | 02:34 PM
turbociv910's Avatar
exhaust leaks preturbo, torn coupler, boost leaks, improper sealing wastegate acctuator
Old Jul 25, 2010 | 04:59 PM
TheShodan's Avatar
Moderator
Not from a boost leak issue, no. Usually replacement is for over 12psi of pressure (from the Honda Greddy kits, anyway) and the flapper door "enhanced" to eliminate spiking
Old Jul 25, 2010 | 09:11 PM
s10cky's Avatar
I'll assume the best way to see if the wastegate is sealing is to pull off the down pipe and check it. I'll just run through everything you guys mentioned, thanks alot for the help.
Old Jul 26, 2010 | 08:35 AM
phunhaus's Avatar
Have you had to lengthen your actuator arm? I had to with a similar setup - GT2871 on an Edelbrock manifold and for clearance ran an arm extender. If you did the same it may be binding or preventing the wastegate flap from closing completely.
You should see your boost come on full at just about 3k - maybe a little under.
Old Jul 26, 2010 | 08:43 AM
s10cky's Avatar
I bought the car like it is. It took me a while to realize that the boost was coming in pretty late. I tried moving the actuator arm and it doesn't move with ease, of course Ive never tried moving one before, so I am not sure how easily it should move.
I am going to replace all the vacuum lines, with new ones, that way I now that part is good to go, and then check couplers, and the actuator.
Old Jul 26, 2010 | 11:09 AM
phunhaus's Avatar
The actuator arm should move easily. See if you can easily take off the downpipe and verify that the flap is 100% closed.
jo-jo123
Jul 8, 2009 11:39 AM
boostnbee
Dec 15, 2008 09:12 AM
red_hatchback
Jul 26, 2007 05:57 PM
civicgeek133
Dec 4, 2006 02:29 PM
wade
Oct 25, 2006 03:52 PM
