Removing oil drain line
Old Jul 6, 2010 | 06:10 PM
MrDomino's Avatar
Default Removing oil drain line
I realize this is probably a noob question but I didn't assemble the turbo system that's on my car now so I am not sure about this. I'm doing a rebuild on the turbo and while ripping everything out I found that the oil return line has seen better days. I ordered a new one in the mean time but for the life of me I can't get the oil return line off of the oil pan. I don't know if it uses a barb fitting or what but I have been yanking on it for a while now and it has barely moved. Do I need to drop the oil pan?
Here is the line in question.
There was a hose clamp that I took off.
Old Jul 6, 2010 | 06:56 PM
Fr0z3N's Avatar
Default Re: Removing oil drain line
have you tried twisting it or heating it up and twisting it?
Old Jul 6, 2010 | 07:20 PM
MrDomino's Avatar
I haven't really been able to twist it yet because it's also stuck on the turbo. I'm going to get some allen wrench sockets tomorrow to see if I can get them to move using a breaker bar. I may also hit it with a propane torch to see if it works.
Old Jul 7, 2010 | 06:02 AM
EsotericImage's Avatar
Retired Moderator
i wouldnt use a torch man. Take off the turbo side, then try to twist this off. After looking at the brown stuff on the pan, i think the might have used some type of adhesive..If its not leaking I would just use it.
I dont see a weld in tap, so i dont know how they rigged that together.
Old Jul 7, 2010 | 06:05 AM
wantboost's Avatar
Who is Mr Robot?
thats just janky
Old Jul 7, 2010 | 08:30 AM
wmac's Avatar
looks like jb weld.
i bet it doesn't leak.
probably a barbed fitting.
get some channel locks and twist the hose 'til it works free.
MalcolmV8
Dec 5, 2011 05:29 PM
95lscivic
Feb 24, 2010 06:41 PM
slo_crx
Oct 6, 2004 08:30 AM
torr
Apr 14, 2004 07:48 AM
AutoboTxEK
Nov 29, 2001 12:16 PM
