Find me some more power
Old Jul 19, 2010 | 06:37 AM
TooSmooth's Avatar
Default Find me some more power
im currently running a stock b18c1 (healthy compression) w/
SC61
inline pro cast manifold
precision intercooler
2.5 charge pipes
aebs intake mani
650 cc injectors
neptune rtp
3 inch downpipe to exhaust
the car still has a/c and p/s and a recirculated dump tube
on 10psi the car only put out 270-275 whp on a dyno dynamics
i wanted the classic 300+ whp out of this set up but i didnt get it.. any ideas?
Old Jul 19, 2010 | 07:02 AM
kyden's Avatar
Default Re: Find me some more power
up the boost, or if you really only want a number try a dynojet?
Old Jul 19, 2010 | 07:13 AM
TheShodan's Avatar
Moderator
You should be able to do that with the current setup, honestly. Time to look at the tuner, and check the type of fuel you're using, in addition to the amount of advanced timing is being performed with the tune.
SC61 is a BIG turbocharger, and has been known to do a lot CFM without much boost over what you're expecting.
Old Jul 19, 2010 | 08:11 AM
LS AzZkIkr's Avatar
I made 309 with less boost and we have about the same setup. I just have an Ebay turbo. But every motor is different. How much experience does you tuner have?
Old Jul 19, 2010 | 08:27 AM
boostedeg302's Avatar
You would make more power without the recirculating dump tube but depends on if your up for that. 2 more psi wouldnt be too much more stress on the engine and would probably make a good amount more power with that turbo.
Old Jul 19, 2010 | 08:44 AM
TooSmooth's Avatar
tuned by chris harris at xenocron
Old Jul 19, 2010 | 08:56 AM
GEN2 LS's Avatar
Loved
switching the wastegate dump to the atmosphere would pick up a bit of power.
Old Jul 19, 2010 | 11:53 AM
EsotericImage's Avatar
Retired Moderator
methanol kit?
Old Jul 19, 2010 | 01:12 PM
TooSmooth's Avatar
its a cool 70 out right now and it definitely pulled harder, my engine bay is an inferno when its 90 out, any metal part in the bay can burn you...
Old Jul 19, 2010 | 01:31 PM
unlimited[nyc]'s Avatar
The first thing people do is blame the tuner.
Old Jul 19, 2010 | 04:59 PM
heavy duty's Avatar
The car is fine the dd just read low. My friend has a dd and i seen a stock gsr with 11psi on it make 305 and it was a egay set up on it. Car is fine just turn it up a little. My car made 518 on a dd and it traped 139.
Old Jul 19, 2010 | 05:33 PM
Silva Bullit DC4's Avatar
This.
OP, how far does your dumptube go down into the downpipe before it terminates? Just curious. Me, I would just take it back to Chris turn up the boost a little on a retune until it reaches 300, or if you're happy with how it feels in cooler weather when your IAT's are down, roll with what you have.
Old Jul 19, 2010 | 07:09 PM
TooSmooth's Avatar
it is flush and dosnt enter the downpipe.. i feel like i should make a cold air intake for the turbo.
Old Jul 19, 2010 | 07:44 PM
Charlie Moua's Avatar
http://www.mnhondas.com/showthread.php?t=9743
B18C1 stock head/block
ITR style intake manifold
68mm TB
FIC 1000cc injectors
Skunk2 rail
Comp Clutch Stage 4
MAPerformance Stage 2 Turbo kit
http://www.maperformance.com/complet...-complete.html
343whp/249tq at 10psi....
so 270whp seems pretty low
Old Jul 19, 2010 | 07:59 PM
da_dude's Avatar
Look at my sig. Different dyno will read different numbers. They don't call the dyno dynamic a heart breaker dyno for nothing.
Old Jul 19, 2010 | 08:06 PM
paulzy's Avatar
word
Old Jul 20, 2010 | 07:24 PM
TooSmooth's Avatar
i also have a slim fan right next to the air filter that is on 75% of the time blowing air around it.. is that an issue?
Old Jul 20, 2010 | 07:42 PM
TheShodan's Avatar
Moderator
My comment was directed to "speak" with the tuner, not replace him, or place blame. Talk to him about what he performed, and why, learn about his "style" of tuning and if perhaps there were other elements that he may have not been aware of that may affect some parameters of the tune.
Old Jul 20, 2010 | 07:45 PM
I say open dump under oil pan and hit up a dyno jet on 12 psi and you will see much better numbers
Old Jul 20, 2010 | 08:42 PM
civicjunkie17's Avatar
because thats usually the problem... that dudes car should easily hit 300whp... **** stock b18b1 motors easily hit 300 on about 15 pounds with alot smaller of a turbo... and not to be dick riding or anything but i wouldnt doubt TheShodan, 99.9% of the time he's dead on accurate.
3gdean
Sep 20, 2014 09:34 AM
H22AJSPEC
Sep 28, 2013 02:49 PM
sanman000719
Jan 4, 2010 02:20 PM
fishieman
Sep 27, 2008 02:24 PM
StolenTeg
Sep 13, 2005 06:41 PM
