Causes of boost leak???
Old Jul 23, 2010 | 08:20 PM
accord99power's Avatar
Default Causes of boost leak???
Need some expert advice. I use to hit 10 psi on the setup in signature. Now hitting 7-8psi sometimes drops to 5psi.
Heres what i have tested so far, can you guys please tell me what time missing.
-I don't notice much of a performance drop
-I completely reinstalled with new piping and connectors for the whole turbo plumbing after the problem began.
-I increaed the boost on the mbc , no difference
- i used a hand pump to test the line going to the boost gauge, no leak.
What are other causes of boost leak? wastegate? BOV? thanks for your time.
Old Jul 23, 2010 | 08:59 PM
90blackcrx's Avatar
Default Re: Causes of boost leak???
Hook up a boost leak detector instead of asking people on honda-tech and waiting for an answer.
Couplers, map, tps, iacv , intake air sensor, throttle plate ( where the throttle cable attached and the piece that goes into the throttle body ) , intake gasket, fuel injector seals, vacuum lines, blow off valve...
Old Jul 23, 2010 | 09:04 PM
Already planned on doing the boost leak detector maybe i should rephrase what are areas to inspect beside the areas i listed. Sounds like you covered them, thanks!
Old Jul 23, 2010 | 09:06 PM
90blackcrx's Avatar
No problem, get a bottle of soapy water also, that helps. Also forgot to add the throttle body gasket.
johnisenglish
Jan 24, 2003 08:18 AM
ludelvr
Aug 25, 2002 10:40 PM
ion_four
Aug 12, 2002 07:59 AM
Aeka GSR
May 22, 2002 11:16 PM
Mucackus
Apr 26, 2002 06:18 PM
