oil feed fitting for integra
what fitting do i need for the back of the block on a 94 integra gsr for the oil feed line to the turbo, i picked up a fitting from home depot but it didnt do the job, oil came pouring out when i started the car. So what fitting do i need?
what parts do you already have? that will help make the decision on what you need to fix your issue's.
normaly, i use 1/8npt to -3an flare. and a -3 feed line to the turbo.
if you have a big oil leak back there and you already have the proper fittings, you could have cracked the block where the oil pres. sender threads into.
Isn't the back of the block bspt? Actually I know it is.
http://stealthmodeperformance.com/oil.shtml
