thickest y8 head gasket?
What's the thickest head gasket I can safely use on a d16y8 running 9-11lbs? I'm trying to lower the cr as much as possible.
Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 »</TD></TR><TR><TD CLASS="quote">save your money and get ARP studs or throw it towards tuning, thats the best thing you can do. OEM headgaskets are fine.</TD></TR></TABLE>
Re: (fmfkid250)
I'll have arp head studs, and I'll get a tune immediately after finishing my boost project. My problem is that the motor was already built for high comp. The srp pistons alone yield a 10.5:1 cr with the oem gasket. Right now, it has a thinner cometic head gasket, bring the cr to nearly 11.0:1. I don't think I wanna run 9-11lbs of boost with that, or even the 10.5:1 cr I would get with an oem gasket, no matter what kind of tune I get. I live in CA, highest octane fuel I can get at the pump is 91!
i ♥ snails
look at b-series tard they run 10:1 to 11:1 compression stock cast internals without problems. You have upgraded internals, and aren't going to compromise on tuning i hope.
i ♥ snails
that just means youll need less boost to hit your goals. Your first mistake is saying you want o run 9-11psi that means pretty much dick without the turbo youll be using, its all about cfm.
Freshdot
09-20-2010 10:41 AM
Joeski99Si
04-22-2009 09:57 PM
superhatchbackbros
11-14-2007 06:00 AM
