Has anyone seen something like this??
Old Aug 14, 2007 | 03:38 PM
MikeNice's Avatar
Default Has anyone seen something like this??
I recently boosted my stock B20-VTEC and drove it untuned (REAL STUPID, I KNOW). As a noob to boost, I couldn't help myself. I really only beat on it for like 1 day which was enough to mess it up. Anyway on the way home late one night I decided to hit it alittle on the open highway and around 6-6500 rpms I noticed alot of smoke coming out the exhaust and I immediatly let off and slowed down. After a few minutes I started to notice smoke and burning oil fumes coming from the vents and the floor board. I got it home and saw oil all over the engine bay and the dipstick was gone. I then checked my plugs and noticed oil on my plugs for cylinder #3. I cleaned them up and started the car and it had that mis-firing sound (Like a WRX) and alittle smoke was coming out the exhaust. I turned it off and did a compression test and got 90 in cylinders # 1,2, and 4. I got like 5 in #3. I then took the head off and this is what I saw. The head looked fine so where is the rest of my piston?? I think it might have been detonation but I'm not sure. Any thing will help, thanks in advance.
CYLINDER #3---------------------------
Old Aug 14, 2007 | 03:44 PM
Sr420Det's Avatar
You melted the piston great job now I dont feel as bad.
Old Aug 14, 2007 | 04:26 PM
CO_CReX's Avatar
Ya you melted your piston for sure, it didn't go anywhere just got way to hot and melted.
Old Aug 14, 2007 | 04:47 PM
A.E Motoring's Avatar
Default Re: (CO_CReX)
LEAN=MELT ****!!!
Old Aug 14, 2007 | 04:50 PM
SuperTeg95's Avatar
Default Re: (Dual Cam Racing)
Well I dont guess you'll do that again...
Old Aug 14, 2007 | 04:55 PM
MikeNice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dual Cam Racing &raquo;</TD></TR><TR><TD CLASS="quote">LEAN=MELT ****!!!</TD></TR></TABLE>
Yeah you right!!! Ok one thing tho. My car smelt of gas but my A/F gauge was pinned on Lean. I even checked my engine to make sure if I was leaking fuel and not mistaking it from the exhaust. Also could I have damaged my valves even tho they look fine.
Old Aug 14, 2007 | 05:04 PM
Default Re: (MikeNice)
wat kinda a/f gauge is it? autometer?
Old Aug 14, 2007 | 05:29 PM
FactionR's Avatar
jeeze do people not drain coolant before cracking motors in half any more
Old Aug 14, 2007 | 05:32 PM
NJIN BUILDR's Avatar
Default Re: Has anyone seen something like this?? (MikeNice)
Wait until you look at the side of it.It will be spectacular.Usually it won't hurt the valves,but there will be some melted aluminum on the exhaust valves and port.
Old Aug 14, 2007 | 05:35 PM
96 GSR-T's Avatar
Default Re: Has anyone seen something like this?? (NJIN BUILDR)
haha i did the same **** before in my old motor on a hack, blew the dipstick and all and smoke into the vents in the car, pistons looked just the same as yours. Make sure you take the turbine housing off the turbo and check the wheel cause its a possibility that piece of your piston went out your manifold and into your turbo, when mine went it also took out the turbine wheel too, but all 4 of my pistons looked way worse than that
Old Aug 14, 2007 | 06:30 PM
MikeNice's Avatar
Default Re: (FactionR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FactionR &raquo;</TD></TR><TR><TD CLASS="quote">jeeze do people not drain coolant before cracking motors in half any more </TD></TR></TABLE>
Yeah I drained the radiator and the block before I even took the valve cover off.
Old Aug 14, 2007 | 06:32 PM
MikeNice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Wait until you look at the side of it.It will be spectacular.Usually it won't hurt the valves,but there will be some melted aluminum on the exhaust valves and port.</TD></TR></TABLE>
Yeah I couldn't see anything. There is alittle bit more deposits built up on my #3 exhaust valves but nothing unusual.
Old Aug 14, 2007 | 06:35 PM
teddy_dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeNice &raquo;</TD></TR><TR><TD CLASS="quote">I recently boosted my stock B20-VTEC and drove it untuned (REAL STUPID, I KNOW).</TD></TR></TABLE>
big mistake, lucky you didn't blow it and tear everything up. what kind of management? let me guess, none?
Old Aug 14, 2007 | 07:06 PM
philafelman's Avatar
Default Re: (teddy_dc2)
geez, everybody's a hater....everyone knows the guy made a mistake....now help him fix it h-t style!!!
Old Aug 14, 2007 | 07:45 PM
quicksilver1689's Avatar
i ♥ snails
we should make a stick out of these, to show people tuning is key, just one day of driving around took its tole on the pistons/ring lands.
Old Aug 15, 2007 | 06:24 PM
MikeNice's Avatar
Default Re: (philafelman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philafelman &raquo;</TD></TR><TR><TD CLASS="quote">geez, everybody's a hater....everyone knows the guy made a mistake....now help him fix it h-t style!!!</TD></TR></TABLE>
Good look. Appreciate the love.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">we should make a stick out of these, to show people tuning is key, just one day of driving around took its tole on the pistons/ring lands.</TD></TR></TABLE>
U Rite. Def live and learn and you can bet I won't be doing something like that again. Thank god for beaters so I can get around while my car is off the road. Now time for a rebuild.
pimpwagon
May 3, 2009 01:44 PM
boostedjdmdc2
Jan 26, 2009 04:55 AM
HONDA@HEART
Aug 26, 2005 09:51 AM
redteg1
Oct 27, 2002 09:36 PM
TheJuggalo
Jul 27, 2002 08:27 AM
