car not making power?
Old Aug 16, 2007 | 03:46 AM
iTz On!!!'s Avatar
Default car not making power?
Got my car tuned today and im having some problem. Basicly my turbo is losing breath up top when its not suppose to because its a pretty big turbo. What would possibly be the cause of that? Its also not making the power its suppose to, @ 10psi it was at 240hp on a dynojet.
Gsr w/ piston and rods
skunk2 IM
topmount manifold
sc61
44mm tial wastegate
greddy bov
880cc injector
walbro255 pump
Leakdown and compression test is good.
Old Aug 16, 2007 | 04:25 AM
DCxMagus's Avatar
Default Re: car not making power? (NyTeRyDeR gSr)
what excatly do you mean by "losing breath up top?"
are you losing boost up top?
are you never reaching full boost?
slow spool up?
a sc61 can flow a H22a just fine so it shouldn't be restricting up top
do you have a picture of the dyno?
what EMS did you tune on?
basically need some more information to be helpful so list everything you can think of that might help.
boost controller? spring size in the wastegate? yadda yadda
Old Aug 16, 2007 | 04:30 AM
TurboLSVtecTeg's Avatar
Default Re: car not making power? (DCxMagus)
Are you sure vtec in engaging. That may be why your losing power up top.
Old Aug 16, 2007 | 01:22 PM
iTz On!!!'s Avatar
Default Re: car not making power? (TurboLSVtecTeg)
boost is holding and its reaching full boost. Its tuned on s300 and even when its ran on just wastegate spring towards redline the power start to fall off dramaticly. I dont have a dyno sheet right now but i'll try to see if i can get it.
Old Aug 17, 2007 | 03:10 AM
iTz On!!!'s Avatar
heres the dyno sheet
[IMG][/IMG]
hopefully that'll help... thats all i got
Old Aug 17, 2007 | 03:30 AM
boosted k20's Avatar
that turbo is not run n outta breath. from the dyno graph, it looks like u might have some ignition problems. r u using a honda OEM distributor or one of those relica aftermarket ones. if u r that might be your problem. also, how do u have ur dump tube routed? if the exhuats gasses r dump n in the engine bay, around the area of the turbo inlet, that could also be your problem.
at 10 psi, u should be making around 270-300whp
Old Aug 17, 2007 | 04:03 AM
Adriano's Avatar
Default Re: car not making power? (boosted k20)
Check to see if vtec is engaging. How rich is the car? It's possible that tuner left the car really rich on top. The sc-61 will make 550hp and shouldnt run out of breath like that.
Adriano
Old Aug 17, 2007 | 05:16 AM
morgan@synapse motorsport's Avatar
i would check into vtec. would be nice to see the rpms, and where its dropping off. not just mph.
i had a similar problem with my car fixed vtec and picked up around 180whp. lol mostly due to boost creep but whatever i engaged vtec and next pull 180whp more
Old Aug 17, 2007 | 02:01 PM
iTz On!!!'s Avatar
Default Re: car not making power? (Adriano)
That graph was at 15psi or so... It definitely should make way more power then that. I haven't check to see if vtec is engaging but i'll check that. Im running msd 6al with blaster coil... I was having a ignition problem but would that cause the graph to look like that? The ignition was braking up on the dyno on higher boost. And my afr was good... it was around 11.8-12.2 i believe.
Old Aug 17, 2007 | 02:47 PM
building boost's Avatar
yes ignition breakup would cause the graph to look like that. i agree with boostedk20. check your wastegate and make sure you have a dump away from the compressor cover.
Old Aug 17, 2007 | 02:56 PM
iTz On!!!'s Avatar
Default Re: car not making power? (building boost)
we tried to put a stock ignition on and it was still the same... the dumptube is away from the compressor cover... its by the exhaust cover
Old Aug 17, 2007 | 03:19 PM
then change the spark plugs (gap em to around 26), change ignition wires, and try another distributor. it def. looks like ignition problems. check all ur ground wires too.
Old Aug 17, 2007 | 06:24 PM
iTz On!!!'s Avatar
it was gapped at 28 and we tried changing plug wires, and distributor.
Old Aug 17, 2007 | 07:12 PM
94turboeg's Avatar
whats the AFR up in those rpms?
Old Aug 17, 2007 | 07:35 PM
Default Re: car not making power? (94turboeg)
i don't think a/f would cause a breakup like that. even something in the high 10s would rev clean. do you have msd? if you've run out of options i suggest you look to the bottom end. if there's something wrong with it you could have a break up like that.
Old Aug 17, 2007 | 08:56 PM
iTz On!!!'s Avatar
afr was around 11.8 or 11.9. Compression test 180 all across and leakdown was 2-3% all across also
Old Aug 17, 2007 | 09:04 PM
iBrandon's Avatar
how big is ur exhaust piping? and d/p size?
Old Aug 17, 2007 | 11:30 PM
94turboeg's Avatar
Default Re: car not making power? (iBrandon)
what boost controler?
Old Aug 18, 2007 | 02:49 AM
iTz On!!!'s Avatar
2.5 do to 3inch, no cat. turbonetics mbc... but even off the wastegate it was like that. Its definitely not the tuning because i threw on my old tune and injectors and its still doin that
Old Aug 18, 2007 | 02:55 AM
blackeg's Avatar
try gapping the plugs tighter. looks perhaps like an ignition thing and not fuel related.
also, if your dp has a flex section, checck and see that it hasnt collapsed. ive seen it happen before and it will kill all power
Old Aug 18, 2007 | 03:16 AM
iTz On!!!'s Avatar
Default Re: car not making power? (blackeg)
i checked that and the muffler... its all straight through. If i regap the plugs would that throw the tune off?
Old Aug 18, 2007 | 05:26 AM
Danny_EJ's Avatar
Sync your IGN timing Dist + ECU
Old Aug 18, 2007 | 05:36 AM
TinyTitan's Avatar
What do your IAT's look like on the dyno..........check for a boost leak? I had a similar thing happen to me recently..........it held boost (19psi) fine but the IAT's were kinda high and it just wasn't as strong as it should be...................turbo was big enough to push 19psi even though the boost leak was pretty big but it was over spooling big time.....blowing hot air.......just a thought
Old Aug 18, 2007 | 05:38 AM
TinyTitan's Avatar
Default Re: (Danny_EJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danny_EJ &raquo;</TD></TR><TR><TD CLASS="quote">Sync your IGN timing Dist + ECU</TD></TR></TABLE>
wouldn't that show up through the whole dyno? just wondering
Old Aug 18, 2007 | 05:56 AM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NyTeRyDeR gSr &raquo;</TD></TR><TR><TD CLASS="quote">it was gapped at 28 and we tried changing plug wires, and distributor.</TD></TR></TABLE>
try gapping it tighter than 28. I've had to gap plenty of cars tighter than that on power levels that you should be hitting.
