Headgasket? Pics inside...
Old Aug 17, 2007 | 01:17 PM
xxxmikenicexxx's Avatar
Default Headgasket? Pics inside...
Looking for some input here...my car started overheating last week, and I pulled into my driveway before it got very high at all...checked the coolant and I was missing a really big amount. I checked the car running later, no leaks. Compression, 190 solid across. Plugs look perfect. Leakdown appeared fine, although my tester isnt the best so I will check again. Everything seems fine except for the loss of coolant. Oil appears slighly brown but VERY. VERY dirty, cannot see through a cup of it, and its only on 500 miles or so. Heres a pic of what I found under the valve cover. Any input would be appreciated...thanks!
Old Aug 17, 2007 | 01:21 PM
maddog20's Avatar
Default Re: Headgasket? Pics inside... (xxxmikenicexxx)
where you in boost when the car over-heated? or shortly after?
Old Aug 17, 2007 | 01:23 PM
Default Re: Headgasket? Pics inside... (maddog20)
to be honest im not sure...i think it was a good bit after...but the second time it started to overheat, a couple days later when i filled it back up and went for a ride, i was not boosting, it was a good amount after again
Old Aug 17, 2007 | 03:32 PM
TinyTitan's Avatar
i'm having the same issue right now........only pushing coolant into the overflow while in boost......started happening after I ran the timing a little to high at full boost without noticing it........it was pushing coolant badddddddd, then i retarded it and it still pushes but alot less.......
when i did a compression test it was fine
i've been told its the head gasket letting go......just not 100% gone yet
i'll be replacing the head gasket this week so we shall see......
Old Aug 17, 2007 | 04:37 PM
Default Re: Headgasket? Pics inside... (TinyTitan)
Ive also heard of ARP studs relaxing, or maybe I possibly torqued them incorrectly, so I will check the torque on them tonight/tomorrow and with any luck maybe a quick retorque could do it. Wishful thinking, but hey, it helps!
Old Aug 17, 2007 | 05:25 PM
I mean is it just me, or does the oil in the first pic look too brown/milky?
Old Aug 17, 2007 | 06:01 PM
del_slow420's Avatar
i have a friend who was pushing colant out into his over flow and filling it and it was his head gasket both times it happpened.. not possitive but i think it might be the head gasket
Old Aug 17, 2007 | 06:13 PM
quicksilver1689's Avatar
i ♥ snails
yeah thats usually a dead giveaway that the head gasket isn't sealing, is there bubbles in the cooling system?
Old Aug 17, 2007 | 06:18 PM
Blackturboteg's Avatar
Default Re: (quicksilver1689)
Sup MikeNice
Always a bummer when S*** like this happens hey i got to go through the same stuff here very soon when we start my motor up . U are handling it very nicely. I would be flipping
Ill answer for him Quick I was right with him doing some of the testing and when he ripped off the valve cover. No bubbles in the Rad. And like he said it was like green sludge on the vavle cover . If u look at the second pic there is a line through the oil that was from my finger and i mean this stuff was thick.
Old Aug 17, 2007 | 07:34 PM
Default Re: (Blackturboteg)
Yo blackturboteg,
Im def tryin my best to not flip out and just take it easy. Theres always gonna be probs with a boosted car, and yeah man well def have our share with your car too. But f it, thats part of the game lol
Yeah like he said, I used my leakdown tester to pump air into the cylinders, no bubbles in coolant. No leakage anywhere. Only indications of anything possibly wrong is that gunk, dirty oil, and loss of coolant. Any more input anyone? Id like to get a good idea of the problem, because if its def the headgasket, id like to bang that out tomorrow. Of course, Id rather not so id like to be pretty much sure thats the prob...
Old Aug 17, 2007 | 07:39 PM
integraRS-T's Avatar
ughhh,loocks like diarrhea ,thats some dirty oil i saw coolant mixed wit oil on dipstick before but that **** is dirty that u have
Old Aug 17, 2007 | 07:44 PM
Default Re: (integraRS-T)
Yeah MIKE how would u bang it out tommorw lol u dont have another headgasket. LOL dude you know me id be flippin the F***** out lol. But like u said it all part of the game which sucks. Let me know if anything i will when ever.
Old Aug 17, 2007 | 07:58 PM
Haha well i mean id have it ready to go on, 2 day it and have it done asap. LOL
So anyone? Whats the verdict?
Old Aug 17, 2007 | 07:59 PM
oh and diarrhea? LOL never thought of that. does mine look like the stuff you saw? like similar at all
Old Aug 17, 2007 | 08:07 PM
Default Re: (xxxmikenicexxx)
blackturboteg,
wait, correction, i DO have a headgasket, its just 81mm not 83
Old Aug 17, 2007 | 08:30 PM
Default Re: Headgasket? Pics inside... (Mr Wonderfull)
Lol Mike the oil looks like poop or even worse .. and most likely the headgasket . Uve done plenty of test and all looking towards the headgasket. we will rip it apart and find the problem. and fix it. where did u get the other gasket and the 2mm differecne what does that affect? do u have to mod it?
and will i have to worry about my arp's relaxing and/or what can i do to prevent future prob?
Old Aug 17, 2007 | 09:07 PM
TinyTitan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Wonderfull &raquo;</TD></TR><TR><TD CLASS="quote">
yup sounds like u lifted the head.. gasket will go shortly...</TD></TR></TABLE>
do you think my ARP headstuds i have in there will be fine? if i just change out the gasket and re-torque them down?
Old Aug 17, 2007 | 10:18 PM
TinyTitan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Wonderfull &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
i take that as a......yea they'll be fine haha
Old Aug 18, 2007 | 03:00 AM
blackeg's Avatar
what sleeves do you have in that motor?
ive been having constant problems like that with my aebs sleeves, especially last year. long story short, the hg wasnt sealing properly and it was mixing along the gasket
Old Aug 18, 2007 | 07:52 AM
Default Re: Headgasket? Pics inside... (blackeg)
Benson
Old Aug 18, 2007 | 03:36 PM
Well, I tore everything apart today and checked torque on headstuds. Did not appear off by much, or any. Hard to tell at that high of torque. I torqued a couple extra lbs and Im putting everything back together to see what happens.
Until then, I could use some more input..anybody?
Old Aug 18, 2007 | 05:20 PM
So mike see anything out of the ordinary.
Lissav
16
Jun 30, 2012 07:37 AM
wrXtian
Honda S2000
Sep 22, 2010 07:34 PM
SiRkid
10
Mar 6, 2007 10:08 AM
eg2wes
Dec 25, 2005 05:11 PM
boostinb18
Oct 29, 2002 02:18 PM
