moroso catch can help
Old Aug 14, 2007 | 02:46 PM
blueintegra's Avatar
Default moroso catch can help
Sup ppl i have been doing some research i cant find the answer. Can u guys on HT HELP ME thanks in advance. The problem is everytime i smash my turbo gsr hard oil leaks alot. i checked under my car found a hose one end is connected to the bottom of the oil catch can and 1 end is not and that is where the oil is leaking from whats wrong with my engine and lost alot of power. PLEASE HELP ME
Old Aug 14, 2007 | 03:24 PM
96 GSR-T's Avatar
Default Re: moroso catch can help (blueintegra)
does the catch can have 2 ports on it? if so connect the hose to the other port.
Old Aug 14, 2007 | 03:35 PM
Default Re: moroso catch can help (96 GSR-T)
YES THERES 3 PORT
TWO PORTS ON THE TOP IS CONNECTED TO BLOCK AND THE 1 ON THE BOTTOM PORT WHERE OIL IS LEAKIN IS NOT
Old Aug 14, 2007 | 03:46 PM
Astig's Avatar
There should be a draincock for the bottom port.
Old Aug 14, 2007 | 03:51 PM
Default Re: moroso catch can help (Astig)
wats that???
Old Aug 14, 2007 | 04:21 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueintegra &raquo;</TD></TR><TR><TD CLASS="quote">YES THERES 3 PORT
TWO PORTS ON THE TOP IS CONNECTED TO BLOCK AND THE 1 ON THE BOTTOM PORT WHERE OIL IS LEAKIN IS NOT </TD></TR></TABLE>
Do you have a hose on the bottom T'eed into one of the hoses from the block to the catch can? If your Moroso has 2 ports up top apparently it is an Endyn modified Moroso Catchcan unless you modified it.
Rereading your original post if one end of the hose end is connected to the bottom of your can then like I said above Tee it into one the other hoses so it will drainback.
Old Aug 14, 2007 | 04:29 PM
Default Re: moroso catch can help (Boostfed.com)
no its not t'eed i have dis http://www.theoldone.com/compo...t.jpg catch can soo wat do i do??
Old Aug 14, 2007 | 04:30 PM
Old Aug 14, 2007 | 04:43 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueintegra &raquo;</TD></TR><TR><TD CLASS="quote">no its not t'eed i have dis http://www.theoldone.com/compo...t.jpg catch can soo wat do i do??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueintegra &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
OK in that picture it shows the Black T, take that Tee and cut one of the hoses going from the back of block to the catch can, tee into that line, take teh line from the bottom of catchcan and connect it to the leftover barb on the Tee, want to do it low as possible on the line
I am sure it is posted on Endyn's website how to set it up and also in teh Crankcae Ventilation thread on here. Good luck
Old Aug 14, 2007 | 05:53 PM
where can i get 1 tee connector???
Old Aug 14, 2007 | 06:03 PM
mike1114's Avatar
Old Aug 15, 2007 | 09:02 AM
I want to thanks all of u guys that help me i think thats the solution goin to go find me a t'ee soo thanks alot
Old Aug 15, 2007 | 09:12 AM
Mr.Death's Avatar
Default Re: (blueintegra)
Slow down......think first then type. You make yourself look like a fool when you post with little or no punctuation. Seriously.
blueintegra
Jul 29, 2007 08:12 PM
top
Mar 19, 2007 01:31 AM
teddy_dc2
Aug 10, 2006 06:11 AM
Fatty_1775
Jul 27, 2006 06:06 PM
DaveF
Mar 4, 2005 06:00 AM
