wastegate
Old Aug 10, 2007 | 10:17 PM
H22Honda98's Avatar
Default wastegate
what exactly does the size of the wastegate control?(mm)- 35-38mm seems common, does that control the boost potential? i have searched, i just cant find the particular answers im looking for. thanks for the help.
Old Aug 10, 2007 | 10:35 PM
DCxMagus's Avatar
Default Re: wastegate (H22Honda98)
that amount of exhaust gas bypassed to keep the turbo at a certain boost level.
if your waste gate is too small you'll have boost creep
if your waste gate is too large you will have an unneeded increase in spool time, if it's way too big you may not even be able to reach your desired boosted level.
basically when your waste gate opens it crease a hole in your exhaust system before the turbo to stop the turbo from spooling itself into oblivion.
if ya want more info google "how an external wastegate works"
Old Aug 10, 2007 | 10:46 PM
H22Honda98's Avatar
thanks a lot for the help
blumeany
Nov 14, 2003 09:44 AM
TurBoXBirD16
May 10, 2003 11:47 AM
Screamer
Mar 28, 2003 10:01 AM
B20-T
Aug 3, 2002 04:31 PM
