does this coolant route seem fine
Old Aug 15, 2007 | 10:56 PM
IntegraTypeR's Avatar
Default does this coolant route seem fine
hey guys,
i always hear when coolant lines of a BB turbo connected to the engine cooling system that coolant temps increases like 10*....now i want to make sure i did this right!
i live in a hot area and i removed my heater out of this engine since i never use it and at the same time to have some usable space....now the turbo coolant hoses i have are hooked from a welded bung on the water neck pipe and another hose to a custom fitting i made that used to be my heater return at the VTEC soleniod area
here are some pics:
is there any chance i could overheat with this setup? or am gonna be fine? since expecting increase of ECT when those coolant lines are used, by how much should i expect more in terms of increase?
Old Aug 16, 2007 | 12:00 AM
haydenpothoven's Avatar
Default Re: does this coolant route seem fine (IntegraTypeR)
yes that should be fine, basically the same way i run mine.
I cant answer your other questions tho sorry.
Old Aug 16, 2007 | 12:48 AM
Default Re: does this coolant route seem fine (haydenpothoven)
thanks man!
any more detailed info here?
Old Aug 16, 2007 | 07:49 PM
bump regarding the questions i asked!
Old Aug 16, 2007 | 10:01 PM
no one can really say if it will/wont overheat because all cars/cooling systems are different...
Old Aug 17, 2007 | 07:20 AM
oh well i'll see how it goes then!
dartonh22
May 5, 2008 01:18 PM
95dc2teg
Sep 24, 2007 08:15 PM
MooreBoost
May 19, 2004 05:06 AM
vti-R
Apr 8, 2003 05:56 AM
