turbo b16
Old Aug 15, 2007 | 04:17 PM
umair's Avatar
Default turbo b16
this winter i might be turbo charging my car(i have a b16). my goal is to get 270-300 WHP. can my motor handle that(it has 2000 miles on it)? also can a 14b turbo make that much power, if not what turbo do you guys recommend to get? also will a fuel pump from a 3000gt vr-4 fit on a civic(i saw a video of a civic hatch that had one)?
hear is what i think will get me to that hp range.
low compression head gasket
walbro 250 fuel pump(or vr4 fuel pump)
550cc or bigger injectors
hondata s200 or 300
turbo?????
psi???
type r cams(maby)
8lbs flywheel(already on car)
i also wanted to know if headstuds will do any good and will my xtd stage 2 clutch be able to handle that power?
Old Aug 15, 2007 | 04:47 PM
teefunk01's Avatar
Default Re: turbo b16 (umair)
14b is too small, forget the 3000gt fuel pump and just get a walbro save yourself the trouble, I am also doing a b16 turbo setup...hoping for somewhere between 300-320 with the stock longblock on a very simple turbo setup
Old Aug 15, 2007 | 06:22 PM
93CX's Avatar
Default Re: turbo b16 (teefunk01)
Nice.. 300whp on a 14b sounds great
..Good luck
Old Aug 15, 2007 | 06:24 PM
fmfkid250's Avatar
there was like the same thread last week
You need a bigger turbo my friend
Old Aug 15, 2007 | 08:55 PM
umair's Avatar
Default Re: (fmfkid250)
i never said that i am going to get a 14b turbo, i just asked if it will make that much power. what i really want is a fast spooling car that makes close to 300 WHP. what turbo would be good for that?
sorry for all the noob questions.
Old Aug 15, 2007 | 09:15 PM
94c1v1cex's Avatar
Default Re: (umair)
t3 .42 .48?
Old Aug 16, 2007 | 06:25 AM
fmfkid250's Avatar
get some like you dont want the turbo to MAX out @ 300hp just because you want 300hp ur Intake air temps will be to high
Civic89stdB16
Jan 20, 2010 04:30 PM
slowcrxsib16
Aug 27, 2006 10:43 AM
Silkk Tha Shocker!
Jun 3, 2006 10:05 PM
Mr si99
Apr 29, 2005 06:09 PM
KiNG $h!t
Jun 29, 2004 02:01 PM
