Easiest to use oil lines??
I was wondering if there are any plug and play oil lines you can use for a turbo kit. I am putting a DSM 16g on my d15b vtec and was curious if there is a kit I can use versus tapping the pan etc. I have never done that before and would not know where to get/return the oil?
You can pick up an oil sandwich plate to get your feed line from and if you dont want to tap your pan you can see if Moroso or someone makes a pan for your application that will come pre-tapped for a return line.
Have a look here ***Forced Induction Forum FAQ*** all kinds of info for oil lines.
ok thanks for the help. I was hoping there was something easy and cheap. looks like the cheapest will be to tap the oil pan. Where would I get one of those sandwich plates??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snafubmx234 »</TD></TR><TR><TD CLASS="quote">Stealthmode Performance is all you need.</TD></TR></TABLE>
Dam right
Dam right
