cracked block. can i reweld??
cracked my block at the oil pressure sensor the other day. does this look like i can reweld it or should i be shopping for a new block?
heres the piece that broke, and the reason why
this is what it looks like if i put the piece back on there
You may want to weld is Shut then Get a oil Sandwhich....
that beat though i would be pissed
I think thats an obd0 block
Modified by fmfkid250 at 6:35 PM 8/16/2007
Re: (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP »</TD></TR><TR><TD CLASS="quote">Just leave it open .</TD></TR></TABLE>
Re: (fmfkid250)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmfkid250 »</TD></TR><TR><TD CLASS="quote">You may want to weld is Shut then Get a oil Sandwhich....
Modified by fmfkid250 at 6:35 PM 8/16/2007</TD></TR></TABLE>
Re: (HT Chaplain)
Oil sandwich would be the best thing to do, but if you find a good welder who does cast aluminum, you could also re-tap it to a different size. I'd go with a 1/4" NPT plug that uses an o-ring too, then put the 1/8" BSPT thread inside of it. I do that for my oil dist. blocks, except I'm going into brass, so no o-ring is needed (I just crank it).
official honda whore
Re: (HiProfile)
should be easily fixed... hell if you wanted to i bet if you cleaned it up good and jb welded that piece on tehre and filled the hole shut you could just use a sandwich adapter and be done with it for cheap
Re: (coptzer)
it's repairable but i wouldn't just run a bead of weld around the crack. take it to a good fab shop who knows how to get the weld all the way through it. then drill and tap.
Re: (gogunkergorilla)
well i have a sandwich, but the 2 ports are taken for my vtec feed and turbo feed. out of that hole i had my oe oil pressure and my autometer oil pressure gauge.
honestly i dont care if i can use that as a port anymore, just so long as it doesnt leak. im really trying to not take the block completely apart as im tired of buying pistons and rings. there is a plug on the back of the oil pump that im considering tapping a 1/8 into the middle of and using that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX »</TD></TR><TR><TD CLASS="quote">What block is it? If its a D series or just a normal B series block save the trouble and get another one.</TD></TR></TABLE>
haha i should only be so lucky. its an 84mm aebs sleeve b18a block. ******* thing has 195 perfect compression and 10-12% leakdown too, so yeah im not a happy person right now
Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared »</TD></TR><TR><TD CLASS="quote">are there enough threads left that you can just install a 1/8" pipe plug to block the hole?</TD></TR></TABLE>
no. the top half cracked off about 1/4 inch past the last thread
Re: (thelate1)
This happened to a buddy of mine. I just tapped it deeper with a 1/8 npt tap and locktited a pipe plug in there and used a sandwich adapter for the switch. Did this about 2 years ago and still holding strong. If i remember right i had to grind the starter portion off the tap to get it to go deep enough and not interfere with the oil galley.
preludesi93-arg
06-19-2005 06:44 AM
