Clearance issue with Synapse FPR
Old Aug 10, 2007 | 11:29 AM
Muckman's Avatar
Moderator in Chief
Default Clearance issue with Synapse FPR
I have an Edlebrock Victor X intake manifold so any FPR doesnt easily fit on the stock rail, the return hits the plenum. So I ordered the Edlebrock fuel rail which has an adapter to use the FPR on the end of the fuel rail. So it clears the plenum but now the forward vac barb of the Synapse FPR hits the head now.
Here's a pic. The manifold isnt tightened down all the way here.
Ive emailed Synapse Engineering and PM'd him on here but havent gotten a response in 2 days. I need to resolve this ASAP. Can I remove the 5 cap screws on the top and clock the top half of the FPR?
Old Aug 10, 2007 | 06:41 PM
urbansi's Avatar
Default Re: Clearance issue with Synapse FPR (Muckman)
Honeslty not only is it sad that a company such as Synapse has put so much time and money in to all the claimed R&D that their products have, but simple clearance issues cant be resolved due to customer to supplier contact issues...
If they dont answer in atleast 24 hours i would attempt to take it apart myself, from the picture it looks like it wouldnt be a problem to clock the unit. Is there a gasket in between the 2 peices? If i assume right it should be like any other FPR consisting of a simple spring, but then again they try and re-invent the wheel over there so its probibly got like a little lepracon inside...
GL
Old Aug 10, 2007 | 07:05 PM
Muckman's Avatar
Moderator in Chief
Default Re: Clearance issue with Synapse FPR (urbansi)
Im usually not afraid to crack something open but being $200 and not really knowing how it works I am a hesitent. Im thinking it cant be clocked bc of that adjustment **** on the top prob connects to something on the bottom. Anyways, Im going to give it a shot and if I break it, Ill blame HT lol
Old Aug 10, 2007 | 10:55 PM
Muckman's Avatar
Moderator in Chief
Nope can't be clocked. Im boned.
The adjustment **** goes all the way through.
Old Aug 10, 2007 | 11:49 PM
Dee's Avatar
Dee
Is the VAC barb press-in or screw-in? If it's the screw-in type just change it for a 90* item or ask Synapse to send you a 90* barb.
Old Aug 11, 2007 | 09:10 AM
done's Avatar
why not just rotate it on the fuel rail?
Old Aug 11, 2007 | 09:35 AM
Dee's Avatar
Dee
Default Re: Clearance issue with Synapse FPR (done)
He will probably end up with a different clearance issue (return line).
Old Aug 11, 2007 | 10:58 AM
Boostfed's Avatar
New User
Brian, in the other thread someone else mentioned and I also mentioned teh use of any aftermarket rail and the adapter fitting from Jackson Racing, I know this works. I know you bought all this to work together BUT if it doesn't just get a GE, AEM, BDL whatever Fuel Rail UNLESS you can still mount the FPR standard style on that Edelbrock rail and just get the JRSC piece. Good luck
Edit:On Second thought IF you got the Jackson Racing piece and put it on the end of there I think that would solve your clearance issue anyways. It will clock the FPR 45 degrees or so
Old Aug 11, 2007 | 11:01 AM
twkdCD595's Avatar
so no help yet on this yet from synapse? bump for you since I have seen them reply to other threads but not this one.
Old Aug 11, 2007 | 11:16 AM
Boostfed's Avatar
New User
Also another alternative i, I knowyou may not want to do this BUT you could cut off half of that nipple for the vacuum source and then put the hose and a worm clamp on it or a zip tie. I can't tell BUT is the nipple screwed in? Maybe just get a 90 egree fittiing from somewhere . Sooo many options for you Brian IMO
Old Aug 11, 2007 | 11:23 AM
twkdCD595's Avatar
Default Re: Clearance issue with Synapse FPR (Dee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee &raquo;</TD></TR><TR><TD CLASS="quote">Is the VAC barb press-in or screw-in? If it's the screw-in type just change it for a 90* item or ask Synapse to send you a 90* barb.</TD></TR></TABLE>
x2... press in fitting or screw in?
Old Aug 11, 2007 | 12:11 PM
tony1's Avatar
Default Re: Clearance issue with Synapse FPR (twkdCD595)
Or you could put a stock honda regulator back on the rail and solve all your problems. What is the benefit in using that regulator on a honda?
Old Aug 11, 2007 | 01:29 PM
Turbo-charged's Avatar
Default Re: Clearance issue with Synapse FPR (tony1)
ive had more damn problems on the dyno with aftermarket regulators. swap them out for honda regulators and the problems solved.
ive never seen the synpase regulator...that picture wont work on this computer
Old Aug 11, 2007 | 01:36 PM
gogunkergorilla's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Or you could put a stock honda regulator back on the rail and solve all your problems. What is the benefit in using that regulator on a honda?</TD></TR></TABLE>
1:1 fp w/boost...does the stock fpr do that?? i didn't want to find out the hard way.
Old Aug 11, 2007 | 01:42 PM
Default Re: Clearance issue with Synapse FPR (gogunkergorilla)
yes it does.
Old Aug 11, 2007 | 02:59 PM
tony1's Avatar
Default Re: Clearance issue with Synapse FPR (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">yes it does.</TD></TR></TABLE>
Yup, only reason i see to go with an aftermarket regulator is if you have a really big fuel pump that the oem reg. can't bypass enough fuel to keep the pressure down at low loads (not a walbro). At that point, you've pretty much done the whole fuel system and the regulator should be upgraded to an Aeromotive or Fuel Lab.
Old Aug 11, 2007 | 03:13 PM
spets's Avatar
I dont' know man, the walbro hp pump takes the fuel pressure to 60psi.. pretty high.
Old Aug 11, 2007 | 03:49 PM
tony1's Avatar
Default Re: (spets)
I've done hundreds of walbro pumps and oem regulators with no issues.
Old Aug 11, 2007 | 04:10 PM
mtber's Avatar
It looks like a rocket ship... yeah
Old Aug 11, 2007 | 04:23 PM
B18CXr's Avatar
ditto......
Old Aug 11, 2007 | 08:26 PM
Muckman's Avatar
Moderator in Chief
Default Re: (B18CXr)
Why would I run the stock FPR when I already bought this part? All I need to solve my clearance issue is a 90* barb fitting. This doesnt have to be complicated.
Synapse responded and told me that vac fitting is a M5 x 0.7. Im having trouble finding barb fittings in that size. Summit doesn't have any. Can anyone point me in the right direction?
Old Aug 11, 2007 | 11:18 PM
Scotty Dosent Know's Avatar
Default Re: (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Why would I run the stock FPR when I already bought this part? </TD></TR></TABLE>
Because it fits correctly and works? Oh and it costs about $200 less
Old Aug 12, 2007 | 12:36 AM
duckmanEG's Avatar
Sexy Cheese Cake
Default Re: (Scotty Dosent Know)
Maybe Mcmaster-carr.com They have what seems like a good amount of barb fittings, might want to give it a look. I just put in the m5 x .07 and it give me a list of things to choose from. I click barb, scroll down to metric and give it a look to see if they have what you need.
Old Aug 12, 2007 | 08:19 AM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Why would I run the stock FPR when I already bought this part? All I need to solve my clearance issue is a 90* barb fitting. This doesnt have to be complicated.
Synapse responded and told me that vac fitting is a M5 x 0.7. Im having trouble finding barb fittings in that size. Summit doesn't have any. Can anyone point me in the right direction?</TD></TR></TABLE>
Brian, there is a bolts and fasteners place close to me that has had everything I ever needed in weird fittings and such. I will chekc with them tomorrow to see if they have what you need
Old Aug 12, 2007 | 09:19 AM
B6tPoweredMx3's Avatar
call FASTENAL they have a place in Victor and I think henrietta .
ImportMotorSpec
Aug 12, 2007 07:15 PM
mrbsponge
Jul 28, 2005 07:02 PM
AL ASPIRATED
Sep 1, 2004 09:46 AM
turbonitrousgsr
Jan 24, 2004 07:01 PM
Cole D
Aug 13, 2003 05:27 AM
