high hp boost applications, what spark plugs are you running?
like the topic states. Just trying to decide which plugs to run, some say ngk iridium and some stay stick witht eh v-power. what are you guys thoughts?
Re: high hp boost applications, what spark plugs are you running? (Ef Si)
well how about starting with giving us some more info, at least a hp goal anyways. what are you running now and what problems are you having?
there have been a bunch of threads lately on this. bkr7e seems to be very popular.
we use ngk bkr7e in most applications 500whp and below.
i personally use denso plugs and they have been good for me. the heat range 22(heat range 7 equal for ngk) were good for my setup until about 560whp and it started to break up. then we switched to the ik27(heat range 9) each setup is different though. you dont want to use a plug that is too cold for your application because you will foul them out quickly.
