open wastegate
Old Aug 13, 2007 | 09:29 AM
lsturboswap's Avatar
Default open wastegate
has any one every ran an ls motor with out runing the wastegate back to the downpipe and out somewhere elses ive seen some with the dump tube out the front bumper but isnt it really fuccen loud or is it only loud when it hits full boost?
Old Aug 13, 2007 | 09:38 AM
StockDC2's Avatar
Default Re: open wastegate (lsturboswap)
Please use punctuations... My head hurts.
To answer your question, open wastegate has nothing to do with full boost... The wastegate itself has a spring inside of it and opens to maintain a steady boost pressure, so it you have a 10LB spring and are boosting 15LBs, it's going to open BEFORE you hit full boost... It's LOUD when it opens.
Old Aug 13, 2007 | 10:21 AM
EG civic's Avatar
Default Re: open wastegate (StockDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StockDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
To answer your question, open wastegate has nothing to do with full boost... The wastegate itself has a spring inside of it and opens to maintain a steady boost pressure, so it you have a 10LB spring and are boosting 15LBs, it's going to open BEFORE you hit full boost... It's LOUD when it opens.</TD></TR></TABLE>
Open wastegate as everything to do with full boost (hence the wastegate is controlling boost pressure). But with the original question no, you do not need a dumptube for the wastegate. I have seen many people that have run the wastegate open with no tube on it and also running open downpipe with that too. Its not that loud at all, just sounds good .
Old Aug 13, 2007 | 11:19 AM
HarfordCTR's Avatar
Default Re: open wastegate (EG civic)
I wouldn't suggest running open wastegate. The hot air is going to go right into your turbo inlet.
Old Aug 13, 2007 | 12:05 PM
twkdCD595's Avatar
Default Re: open wastegate (HarfordCTR)
Not to mention any wiring, vac. hose, etc or anything like that will be melted by the extremely hot gases it releases. You will also have a ton of un-ness. heat from not directing the gases under the car or at least toward the ground.
Old Aug 13, 2007 | 12:42 PM
would it be better to run it back to the down pipe or run it out the bumper
Old Aug 13, 2007 | 12:46 PM
like a lil seperate exhaust
Old Aug 13, 2007 | 12:50 PM
twkdCD595's Avatar
atmosphere dump is louder but seems to result in a little more power... as to where recirculated back into the downpipe would obviously be quieter and make slightly less power.
if you dont mind the noise... atmosphere dump is MUCH more fun imo...
Old Aug 13, 2007 | 01:44 PM
mengy007's Avatar
Default Re: open wastegate (twkdCD595)
My dumptube goes down under my oil pan and it's like it's not even there. I'm running a T3/T4 Garret with a TiAL WG and 5psi spring, doesn't sound like I have a leak or anything. It's actually quieter than when I was N/A. I have 2.5" from turbo -&gt; 42" 4" diameter resonator then 2.5" to a brospeed muffer with 2.5" tip. Sounds so quiet, I love it. I'm sure I'd gain more power by opening it up but I love NOT getting attention from cops.
Old Aug 13, 2007 | 02:05 PM
Default Re: open wastegate (mengy007)
gyea im not tryna get attention from cops im planning on power coating everything black come on im from cali fucc cops
D-meet07
Sep 23, 2019 03:06 AM
turbodan4
Mar 7, 2006 09:09 PM
theo99gsr
Aug 1, 2005 09:11 AM
DLB1994
Jan 25, 2004 11:03 AM
01ITR#700
Jun 22, 2003 10:01 AM
