how to baffle vented vc?
Old Aug 16, 2007 | 08:32 PM
laocivic's Avatar
Default how to baffle vented vc?
no luck in civic forum....how do i baffle the hole after i drill it? are there any DIY for vented vc?
Old Aug 16, 2007 | 08:56 PM
Sprockets's Avatar
Default Re: how to baffle vented vc? (laocivic)
You don't. There's an internal baffle
Old Aug 16, 2007 | 10:11 PM
da_dude's Avatar
^^^^ I dont have any for my d16z6.
Old Aug 17, 2007 | 04:26 AM
Mikey3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laocivic &raquo;</TD></TR><TR><TD CLASS="quote">no luck in civic forum....how do i baffle the hole after i drill it? are there any DIY for vented vc?</TD></TR></TABLE>
a plate with holes in it IS the baffle. you don't baffle a hole, the holes make the baffle so to speak.
Old Aug 17, 2007 | 04:35 AM
DaveF's Avatar
Default Re: how to baffle vented vc? (Mikey3000)
Old Aug 17, 2007 | 08:16 AM
laocivic's Avatar
Default Re: how to baffle vented vc? (dturbocivic)
oh ok thanks so i just drill and put the fiitting on then?
Old Aug 17, 2007 | 08:19 AM
HybridKOOP's Avatar
Get some sheet aluminum, and tack in a piece to prevent sloshing oil from jumping into the lines.
Old Aug 17, 2007 | 08:20 AM
DaveF's Avatar
i had a response typed up, and decided to take it down, because its so stupid easy to figure something out for a baffle.
Old Aug 17, 2007 | 08:27 AM
quicksilver1689's Avatar
i ♥ snails
baffles are very complicated these days
Old Aug 17, 2007 | 08:34 AM
tony413's Avatar
Default Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">baffles are very complicated these days</TD></TR></TABLE>
sheetmetel with a hole what will they think of next ?
Old Aug 17, 2007 | 09:01 AM
DaveF's Avatar
Default Re: (tony413)
blingin sheetmetal with a hole
Old Aug 17, 2007 | 09:08 AM
tony413's Avatar
Default Re: (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">blingin sheetmetal with a hole </TD></TR></TABLE>
oh like with 50 carats worth of diamonds an gold plating
Old Aug 17, 2007 | 09:27 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: how to baffle vented vc? (Sprockets)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sprockets &raquo;</TD></TR><TR><TD CLASS="quote">You don't. There's an internal baffle</TD></TR></TABLE>
on the back side there isnt. i will get heat from boostedjeff and turbo-charged for this, but i was thinking of 1" 90* angle aluminum strip.
or just use the front because it is baffled.
i know i am talking b series but it is an idea.
pm rota92 he has a vented d series valve cover.
Old Aug 17, 2007 | 09:58 AM
DaveF's Avatar
Default Re: how to baffle vented vc? (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
how would you attach that,,,,,,, there is no lip to attach it... you need a to use something shaped like ] for the rear [ for the front
Old Aug 17, 2007 | 10:07 AM
Mr. Badwrench
was just a thought....it woulda been welded...
Old Aug 17, 2007 | 10:08 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">was just a thought....it woulda been welded...</TD></TR></TABLE>
gotcha.. it would be easier to rivit the baffle in.
Old Aug 17, 2007 | 10:30 AM
vtekthis's Avatar
gotcha.. it would be easier to rivit the baffle in. </TD></TR></TABLE>
take it from the turbs, rivits in no problem! lol
Old Aug 17, 2007 | 10:33 AM
Mr. Badwrench
Default Re: how to baffle vented vc? (vtekthis)
10-4
Old Aug 17, 2007 | 11:35 AM
Sprockets's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">on the back side there isnt. i will get heat from boostedjeff and turbo-charged for this, but i was thinking of 1" 90* angle aluminum strip.
pm rota92 he has a vented d series valve cover.</TD></TR></TABLE>
I know now that the original poster is talking about D series, but are you saying that there's no baffle on the rear of B series? The stock valve cover vent is underneath the baffle. I posted a pic in another recent thread.
Old Aug 17, 2007 | 03:38 PM
HiProfile's Avatar
If you're going to weld the tubes in, then tack a sheet of aluminum on there while you're at it. Holes drilled near the ends, edges curled up - and ample clearance between it and the valvetrain. If using a pipe fitting & bulkhead nut, you can add the sheet of alum in between the nut and head, then bend as needed. Rivets would look kinda crappy, but would work fine.
All you need is something that blocks a direct path of exit for splashing oil, and preferably does not rub or rattle on anything.
thw_goalie
Honda Civic (2001 - 2005)
11
Jan 10, 2008 09:02 PM
H9Omega
50
Jul 25, 2006 07:51 PM
k7q
Apr 19, 2006 03:25 PM
JDMSI
Jun 19, 2003 07:31 PM
