Engine building question
Old Aug 14, 2007 | 07:48 PM
TurboEK9Coupe's Avatar
Default Engine building question
I am about to build my engine later this week and I have heard mix things about using the Permatex Copper spray gasket on the head gasket. My boss thinks its a bad idea but the machine shop we get all of blocks done at uses it on all of their motors they build. I know that the LS/VTEC's leak oil some times around the number 4 cylinder by the exhaust manifold. I want to use this stuff to prevent any possible chances of an oil leak. What do you think and has anyone used the stuff before? Here is the link to the product.
http://www.permatex.com/produc...t.htm
Old Aug 14, 2007 | 07:57 PM
RCautoworks's Avatar
Default Re: Engine building question (TurboEK9Coupe)
I talked to Earl once before, he said he used to use it just for a safe measure, that was good enough for me .
Old Aug 14, 2007 | 09:14 PM
ninesecrx's Avatar
Default Re: Engine building question (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">I talked to Earl once before, he said he used to use it just for a safe measure, that was good enough for me . </TD></TR></TABLE>
We actually use that same brand, but it is a purple tacky spray called spray-a-gasket I think? We used it just to add with keeping oil and coolant in their proper spots It can't hurt any...
Old Aug 15, 2007 | 01:32 AM
Legion's Avatar
* B A N N E D *
Default Re: Engine building question (ninesecrx)
Sometimes I use it, sometimes I don't. I've never had any problems either way. I say go for it since it doesn't seem to hurt anything.
Old Aug 15, 2007 | 10:12 AM
mike93eh2's Avatar
Default Re: Engine building question (Legion)
if you want to spray your headgasket with something then use hylomar..its only about 300 times better than copper spray.
http://www.hylomar.com/
i get my spray cans from here
http://www.valco-cp.com/Hylomar.htm
udaysinh_patil
Engine Machining & Assembly
Aug 31, 2018 12:46 AM
2157 EH3
Sep 17, 2006 11:22 PM
bb4socal
Mar 9, 2006 03:30 PM
unrefined7
Jan 19, 2006 12:02 PM
VanHonda
Jan 13, 2004 01:27 PM
