turbo?
Old Aug 14, 2007 | 11:20 PM
hspoon's Avatar
Default turbo?
ok... i got a stock ls in a eg coupe...
just got a turbo kit,
my goals right now is to get it runnin,, dont care bout horespower....
my questions are
1) can i use stock injectors, and map sensor?
2) do i really need a turbo timer if its stock?
3) both wastegate and bov lines goes to the manifold?
I WILL REALLY APPRECITE YALLS HELP.....
any comments or advice would help
Old Aug 15, 2007 | 01:38 AM
Legion's Avatar
* B A N N E D *
Default Re: turbo? (hspoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hspoon &raquo;</TD></TR><TR><TD CLASS="quote">
2)and map sensor?
3) do i really need a turbo timer if its stock?
4) both wastegate and bov lines goes to the manifold?
1. Only if you have an FMU
2. Yes, assuming you are boosting 6 or 8psi.
3. You never need a turbo timer, ever.
4. Wastegate goes to compressor housing, BOV goes to manifold
Old Aug 15, 2007 | 07:17 AM
hspoon's Avatar
Default Re: turbo? (Legion)
thanx... anyone else???
Old Aug 15, 2007 | 07:23 AM
bigbadboy's Avatar
vaccume lines are good, map sensor is ok if running under 10lbs, get ur ecu chipped with crome or something install some injectors and get tuned. never run ur car on FMU
Old Aug 15, 2007 | 08:22 AM
Buzzbomb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legion &raquo;</TD></TR><TR><TD CLASS="quote">
4. Wastegate goes to compressor housing, BOV goes to manifold</TD></TR></TABLE>
I agree with all but 4. Actually half agree. It can go to either the compressor housing or intake manifold.
I would recommend the intake manifold so the boost drop across the intercooler is taken into account.
Old Aug 15, 2007 | 08:56 AM
EG civic's Avatar
Default Re: turbo? (Buzzbomb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buzzbomb &raquo;</TD></TR><TR><TD CLASS="quote">
I would recommend the intake manifold so the boost drop across the intercooler is taken into account.</TD></TR></TABLE>
Then the nipple on the compressor housing would you just leave it vented, if you ran the line from the intake manifold?
Old Aug 15, 2007 | 10:23 AM
Buzzbomb's Avatar
Default Re: turbo? (EG civic)
No, you'd have to cap it off if you decided not to use it.
Old Aug 15, 2007 | 12:58 PM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hspoon &raquo;</TD></TR><TR><TD CLASS="quote">ok... i got a stock ls in a eg coupe...
my questions are
any comments or advice would help</TD></TR></TABLE>
1 yes with fmu, no to make any reliable power
2 not really, just idle a minute or 2 then shut off
3 i would like to see the gate go to the compressor, and put the b.o.v. to the pcv line if poss
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG civic &raquo;</TD></TR><TR><TD CLASS="quote">
run that to the wastegate. it is more consistent
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buzzbomb &raquo;</TD></TR><TR><TD CLASS="quote">No, you'd have to cap it off if you decided not to use it. </TD></TR></TABLE>
that is correct
highazamotha
Feb 7, 2010 06:48 PM
99lude+
Apr 29, 2006 06:05 PM
jared99
Nov 27, 2005 07:31 PM
BluntMan
Sep 16, 2004 10:26 AM
