PCV Question???
Hey im getting ready to put my new built B18 in and am wondering which way to do my pcv. Im going to do two fittings out of the valve cover and then on the back of the block was wondering which to do. My buddies around here just tap into the black pcv box and run a hose from it to the catch can. I was thinking of doing the two honda fittings in the back of the block running to the catch can. Would both work the same? Which would you all prefer? Also to plug the pcv hole using a freeze plug what kinda sealer do you use to seal it in there? Because the hole isnt threaded correct?
