upgrading injectors...?
Old Aug 11, 2007 | 07:47 PM
the.hamburglar's Avatar
Default upgrading injectors...?
i currently have a set of 450cc dsm bluetops and it looks as though im going to need to upgrade them. i have an obd1 so i had to install the resistor box. now my question is do i currently have low impedence or high impedence? and whats the difference between saturated and non saturated injectors?
thanks
Old Aug 11, 2007 | 10:08 PM
Joseph Davis's Avatar
Default Re: upgrading injectors...? (the.hamburglar)
You want the dissertation or the brass tacks?
Brass tacks is saturated = high impedance = high Z, peak and hold = low impedance = low Z, and the Honda ECU needs high Z injectors to prevent from drawning too much current so you run a resistor box with low Z injectors to raise the impedance.
The, ah, dissertation takes a bit longer to type.
Old Aug 12, 2007 | 12:37 AM
numbnuts22715's Avatar
you have low impedance right now because of the resistor box just in case you didnt pick that up from joseph's explanation.
all those equal signs and z's made my head spin.
Old Aug 12, 2007 | 09:49 AM
Default Re: (numbnuts22715)
so i have low impedence peak and hold? so i should just get the same kind of injectors if i want something plug and play?
Old Aug 12, 2007 | 12:19 PM
Default Re: (the.hamburglar)
You need either
- saturated injectors (high Z) with NO resistor box
or
- peak and hold injectors (low Z) AND a resistor box
The ECU needs a high impedance injector circuit, you either buy the correct injectors (RC sells them up to 750cc) or you run a resistor box. Either way works great.
Old Aug 12, 2007 | 07:34 PM
xenocron's Avatar
Default Re: (Joseph Davis)
To sum it up...if you dont want to touch your currently installed resistor box, take out the DSM450cc and replace then with a bigger LOW Impedance injector.
Old Aug 12, 2007 | 07:41 PM
Default Re: (xenocron)
I suck at making things simple, sometimes.
Steeve_Civic
Dec 4, 2011 10:11 AM
columbushatch
Jan 17, 2009 11:08 AM
DrivinVtec
Sep 17, 2007 10:08 AM
dave24
Aug 3, 2006 07:43 PM
ppfalcon
Mar 29, 2006 11:53 AM
