need help optimizing p28 ignition maps for a d14 engine -CROME-
Old Aug 11, 2007 | 12:47 PM
RACEPAK's Avatar
Default need help optimizing p28 ignition maps for a d14 engine -CROME-
hello everyone,
i'm driving with base p28 ignition maps on my d14..... how can i make them more optimal for a smaller engine .
thanks
Old Aug 11, 2007 | 01:27 PM
Turbo-charged's Avatar
Default Re: need help optimizing p28 ignition maps for a d14 engine -CROME- (RACEPAK)
the only answer is put it on a dyno.
Old Aug 11, 2007 | 02:10 PM
RACEPAK's Avatar
Default Re: need help optimizing p28 ignition maps for a d14 engine -CROME- (Turbo-charged)
i dont have any option to dyno it whatsoever.
Old Aug 11, 2007 | 07:59 PM
if there's a will, theres a way
Old Aug 11, 2007 | 08:31 PM
HiProfile's Avatar
I'm assuming its a 75mm bore, but with a shorter stroke? If thats the case, the maps don't have to be much different. Since its less air though, you may be able to add a degree or three of timing throughout most of the map. If its the same stroke but smaller bore, you'd most likely have to run a few degrees less ignition timing.
Old Aug 12, 2007 | 06:01 AM
Default Re: need help optimizing p28 ignition maps for a d14 engine -CROME- (HiProfile)
and again....the only way to know for sure is to put it on a dyno lol
Old Aug 12, 2007 | 07:42 AM
RACEPAK's Avatar
thanks for the answers.
yes the bore is 75 but the stroke is 79, cr is 9.1, runing on 95 daily,
the reason i cant put it on a dyno is because i live in israel...
ill explain the rest when ill get back from work
Old Aug 16, 2007 | 06:11 PM
RACEPAK's Avatar
redirecting....: please respond
https://honda-tech.com/zerothread?id=2070527
Modified by RACEPAK at 6:00 PM 8/24/2007
Old Aug 24, 2007 | 05:00 PM
RACEPAK's Avatar
bmp 4 some more info....
Old Aug 24, 2007 | 05:03 PM
mtber's Avatar
You are not going to get a direct answer on the forums.
Start conservative & work your way up on a dyno while monitoring for signs of knock & MBT.
D21X
34
Feb 3, 2015 03:28 PM
4potnick
Engine Management and Tuning
Apr 7, 2009 09:35 PM
flatblackintegragsr
Mar 24, 2007 03:35 PM
scrubachu
Jul 7, 2005 07:52 AM
Mr. Softee
Nov 18, 2001 06:05 PM
