Power Steering elimination kit ???
Old Aug 9, 2007 | 08:01 PM
JDMCRX's Avatar
Default Power Steering elimination kit ???
Ive searched there used to be someone on here selling the power steering elimination kits ? Anyone know who ?
Old Aug 9, 2007 | 08:07 PM
tony1's Avatar
Default Re: Power Steering elimination kit ??? (JDMCRX)
Not much of a kit needed. Take the pump off, take all the lines off, turn the rack back and forth to pump the excess fluid out and you're good.
20 people are going to come on here and tell you the rack will wear out that way, but in 11 years of doing them that way, i've yet to see a failure...
Old Aug 9, 2007 | 08:27 PM
xenocron's Avatar
Default Re: Power Steering elimination kit ??? (tony1)
I'd like to see 20 people argue now...
Old Aug 9, 2007 | 08:28 PM
accordking's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Not much of a kit needed. Take the pump off, take all the lines off, turn the rack back and forth to pump the excess fluid out and you're good.
20 people are going to come on here and tell you the rack will wear out that way, but in 11 years of doing them that way, i've yet to see a failure...</TD></TR></TABLE>
Yeah, I'll be the first to say it'll will wear out. lol!
Listen to Tony. Lock this thread.....
Old Aug 10, 2007 | 12:59 AM
cbustuner's Avatar
Padawan and steatlhmode performance sell them if you really want them,but yea.....^Listen to above advice and save some cash.
If your really that worried about it,some 3/8 rubber hose a "t" fitting, some clamps and a junk yard clutch master cylinder reservoir will work wonders.That's how mine is setup and since I had all the parts laying around it was free and it's basically the same thing as those kits.
Old Aug 10, 2007 | 02:35 AM
JDMCRX's Avatar
Default Re: (cbustuner)
Yeah i was looking at a clutch res for the tank thats what im gonna do save the 75-92 bones. Thanks
Old Aug 10, 2007 | 10:14 AM
Flashmn's Avatar
Default Re: (JDMCRX)
I'd just get the non power steering rack.
Old Aug 10, 2007 | 10:18 AM
Schister66's Avatar
Man U FTW
its not really that hard to do....remove the lines and recirculate the open holes to each other....
Old Aug 14, 2007 | 06:40 PM
JDMCRX's Avatar
Default Re: (Schister66)
Anyone know what size the fitting are on the rack 1/2" NPT or???
Old Aug 14, 2007 | 07:06 PM
94c1v1cex's Avatar
you could also get all the fluid out of the rack... pump good automotive grease in it such as mobil 1 or somethin like that and then loop the lines so you don't have to worry about it... that's what i'm gonna do
Old Aug 14, 2007 | 07:28 PM
cbustuner's Avatar
https://honda-tech.com/zerothread?id=1668986
That thread has the sizes in it and in the link in the thread.
I didnt even use fittings on the rack.The only thing I used fittings on was the "t".My friend had a power steering rack that was in a junk car he stripped so i took the hard lines and fittings, cut the excess line off ,slipped the tube over it, clamped it on,and put it in my ps rack.Only reason I didn't do that to my hard lines was because I was selling my p/s system complete on ebay and didnt want to screw it up.
Modified by cbustuner at 4:53 AM 8/15/2007
Modified by cbustuner at 4:55 AM 8/15/2007
Old Aug 14, 2007 | 08:02 PM
vtec.dc2's Avatar
all you gotta do is loop return/send lines into a t with line going up to reservour tank to catch excess fluid.. pretty simple..
Old Aug 15, 2007 | 07:26 AM
JDMCRX's Avatar
Default Re: Power Steering elimination kit ??? (vtec.dc2)
Thanks guys yeha i know ive looped tons of these but i do not want to cut my factory lines. Every mod i do on the car i do so i can put the car back to OEM in case something ever happens.
blackj30_a
Sep 4, 2016 06:01 PM
jaa1311
Jul 6, 2008 07:24 AM
EJ ITO
34
Sep 17, 2007 01:19 PM
SOHCmaster
May 13, 2005 06:44 PM
-[95cxhatch]-
Apr 12, 2004 01:38 PM
