FREE BOOST GAGE
Old Aug 12, 2007 | 07:13 PM
xXSilentScreamXx's Avatar
Default FREE BOOST GAGE
i got a free boost gage b/c its stuck at like 7vac or whatever can i set it back to 0?
Old Aug 12, 2007 | 07:17 PM
lovey408's Avatar
Default Re: FREE BOOST GAGE (xXSilentScreamXx)
boost guage.... did u try to plug it in and kick in ur boost.. maybe that will push it bak to normal.. if not, since it was free,, open it up and mess around wit it
Old Aug 12, 2007 | 09:33 PM
demonicivis1320's Avatar
Default Re: FREE BOOST GAGE (lovey408)
the nut where you hook up the line to twist it till it is back to 0
Old Aug 13, 2007 | 12:20 AM
a1320honda's Avatar
Default Re: FREE BOOST GAGE (demonicivis1320)
if its autometer, when you pull the light out theres an open hole and if you look inside, you can see a brass ring inside thats pretty big. (kinda hard to explain) But if you mess around with that ring kinda pushing and pulling with a small screwdriver youll notice how the needle moves. Ive gotten a couple of gauges for free cause of the same problem. You just have to kinda bend that ring until it gets the needle back on 0.
Old Aug 13, 2007 | 12:57 PM
Default Re: FREE BOOST GAGE (a1320honda)
yea its out of an srt-4
Old Aug 13, 2007 | 01:07 PM
Schister66's Avatar
Man U FTW
i'm going to sound like a cheap *** on this one, but when i got my boost gauge, it was perfect. It was at 0 and brand new....then i dropped it on the ground by accident. It actually broke inside...a little plastic piece busted off. I decided what the hell...i'm going to take it apart and fix it. I cut the back off, took it all apart and fixed the broken piece. After that, i bent the little metal dealie back and calibrated it with a working vac gauge on another car. It reads perfectly and has for about 1.5 years now....nobody would ever know....
They're fairly easy to fix if you want to put the time into it...if nothing else, you'll learn something in the process
vy3tnamezz
Nov 6, 2008 02:11 AM
Mugen112
May 8, 2006 08:34 PM
dan_w_82
Mar 28, 2006 11:37 AM
S2KP
Jul 24, 2004 06:38 PM
