OBD Ecu's
Old Aug 10, 2007 | 07:19 AM
HondamanXxX's Avatar
GO GIANTS!
Default OBD Ecu's
I have a OBD2 JDM GSR into a EJ8, 98 ex. I am unsure what ECU to use. Keep in mind that later I will be puting Neptune in it. Should I go with a OBD1 ECU p28?
I am very clueless when it comes to ECU's.
I would like to stay OBD2 also if its possible.
Old Aug 10, 2007 | 07:44 AM
HarfordCTR's Avatar
Default Re: OBD Ecu's (HondamanXxX)
you could use an obd-1 Gsr ecu. Then when you want to chip it for neptune it will work too.
Old Aug 10, 2007 | 09:35 AM
Joseph Davis's Avatar
Staying OBD2 != tuning your car.
Are you in a strict emissions area?
Old Aug 10, 2007 | 09:39 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: OBD Ecu's (Joseph Davis)
to go neptune as far as i know, like anyother program like it, you need to go obd1. the only option that i know of with obd2 is e manage/ultimate?
Old Aug 12, 2007 | 07:30 PM
JaredKaragen's Avatar
Default Re: OBD Ecu's (boostedcivicsir)
A guy on PGMFI.org made a OBDII simulator... relaying info fron the datalogging port; in OBDII format through an OBDII port...
I plan to get one, and pass the cali sniffer test with one.
egbaby
Mar 1, 2008 06:52 AM
HondamanXxX
Aug 10, 2007 10:27 PM
superfuji57
Mar 21, 2003 09:19 AM
Fuster_Cluck
Mar 1, 2003 12:58 PM
MeanGreenEG9
Dec 20, 2002 05:49 PM
