b16 t3 thunderbird turbo question
Does anyone no were i can pick a t3 60 trim thunderbird turbo to build a b16 turbo. I am looking to build a turbo kit for my b16 hatch. I am going to be runing 10psi and my goal is to make around 275-300whp does anyone have an other option for a turbo that would maybe be better than the tunderbird turbo that wont cost me an arm or a leg. does any one no how much boost that turbo will go up to efficently because i might put rods and pistons and bump it up to 15psi over the winter and i want a turbo that will have those capabilitys
Re: b16 t3 thunderbird turbo question (civichatch2307)
Go to the junkyard in your area, also check the local classified adds in your area. Those turbos are THE BEST stock t3 turbo out there. It will do just fine up to around 15 psi and not run out of air. Anything over that and you should consider stepping up to something larger than flow more air easier without falling on its face in high rpm and boost.
