Need help buyin a wastegate..
TiAL 38 mm wastegate is what i'm lookin to buy (pictured)
i just needed to know what the "Bar" means since they all cost the same.
.5 Bar $219.95/ea
.8 Bar $219.95/ea
.6 Bar $219.95/ea
.7 Bar $219.95/ea
.9 Bar $219.95/ea
1 Bar $219.95/ea
and if not too much trouble, can someone point me in the direction of some 440cc injectors for a 5th Gen Accord (94-97) F Series Motor.
.TiA
.5 Bar $219.95/ea
.8 Bar $219.95/ea
.6 Bar $219.95/ea
.7 Bar $219.95/ea
.9 Bar $219.95/ea
1 Bar $219.95/ea
.TiA
Re: Need help buyin a wastegate.. (highschooler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highschooler »</TD></TR><TR><TD CLASS="quote">1 bar=14.7psi
.5bar=7.35
Also, you should be able to find a tial 38mm for less than $220</TD></TR></TABLE>
.5bar=7.35
Re: Need help buyin a wastegate.. (oem_certified_accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oem_certified_accord »</TD></TR><TR><TD CLASS="quote">oh. what about the help on locatin them injectors? cant go boost on the oem's.</TD></TR></TABLE>
i like the RC750's biggest i have found saturated = not having to cut in a resistor box and i believe direct plug in for obd1?
Re: Need help buyin a wastegate.. (Insperation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Insperation »</TD></TR><TR><TD CLASS="quote">
.5 bar is 5-6psi spring
.8 bar is 7psi spring
1bar is 14psi spring
Correct me if am wrong</TD></TR></TABLE>
not exactly.
.5bar=7.35
ding ding ding
not exactly.
.5bar=7.35
ding ding ding
Re: Need help buyin a wastegate.. (Mr Wonderfull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Wonderfull »</TD></TR><TR><TD CLASS="quote">
1 bar = 14.5 psi....
atmospheric pressure is 14.7
Contact Mike at LSD Motorsports... They are a HT sponsor----Great deals on Tial stuff...</TD></TR></TABLE>
isent bar a measure of atmospheric pressure?
Re: Need help buyin a wastegate.. (blinx9900)
The Synapse wastegate comes with all the springs you need between 4-25 psi of boost. You don't have to worry about the spring pressures. PM Rob at NoLimitMotorsport
For a little more you get flanges, studs and actual flange nuts. Oh, and for the money, the Synapse is a 40mm not a 38.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Wonderfull »</TD></TR><TR><TD CLASS="quote">1 bar = 14.5 psi....
atmospheric pressure is 14.7</TD></TR></TABLE>
yea now that's right
Re: Need help buyin a wastegate.. (agrn93ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agrn93ls »</TD></TR><TR><TD CLASS="quote">i like the RC750's biggest i have found saturated = not having to cut in a resistor box and i believe direct plug in for obd1?</TD></TR></TABLE>
accords have resistor boxes from the factory BTW, so just get some dsm 450's for cheap...
civic_jdm
06-23-2005 03:36 AM
Kwuaymaikrup
10-25-2003 10:42 PM
