Adding more fuel?
Old Aug 13, 2007 | 10:05 AM
eg_gsr11's Avatar
Default Adding more fuel?
Hey guys. i was wondering if its safe to add fuel w my adjustable fuel pressure reg. on my own? (i.e. w/o taking it on thw dyno) i got dsm 450's on my turbo gsr with a conservatively tuned chipped ecu and was wondering also if adding a few more psi of fuel would help me run more rich at WOT.
Old Aug 13, 2007 | 10:08 AM
bigbadboy's Avatar
no not if its already tuned. just leave it alone
Old Aug 13, 2007 | 12:20 PM
integraRS-T's Avatar
Default Re: Adding more fuel? (eg_gsr11)
if u turn the fuel pressure up u need to retune
Old Aug 13, 2007 | 12:34 PM
Schister66's Avatar
Man U FTW
what do you hope to gain from bumping the fuel pressure anyway?
Old Aug 13, 2007 | 08:25 PM
bigbadboy's Avatar
just leave it alone ur not going to gain any HP
Old Aug 13, 2007 | 08:26 PM
Schister66's Avatar
Man U FTW
Default Re: (bigbadboy)
the way i see it, the only thing you're going to do is lose power and ruin your gas mileage...
Old Aug 13, 2007 | 09:56 PM
DCxMagus's Avatar
unless you have a wide band TELLING you that your running lean you shouldn't change it, butt dynos aren't accurate by any account. Also if you have a "conservately" tuned ECU you probably running enough rich already you turn up that PSI you could potentally wash you rings and then you'll blow the motor because gas will start to mix with your oil and break it down.
so no it is not safe to adjust your fuel pressure without the proper knowledge and gauges, if you have those you wouldn't ask this question so I wouldn't touch the fuel pressure if I was you.
Old Aug 14, 2007 | 09:47 AM
eg_gsr11's Avatar
Default Re: Adding more fuel? (DCxMagus)
Awsome thanks for the response guys. i'll take it to the dyno next week and do it the right way.
Old Aug 14, 2007 | 02:40 PM
Topdawgg's Avatar
too much fuel can be just as bad as not enough... period...
s032105k
11
Apr 14, 2011 08:01 PM
Igaly
Honda Civic (2001 - 2005)
Apr 16, 2009 03:17 PM
OMGWTFBBQ!
May 30, 2008 01:07 PM
B-B-K
Aug 1, 2004 03:09 PM
DR. ON POINT
Apr 4, 2002 02:07 PM
