Forever To build boost...??
Old Aug 13, 2007 | 06:32 PM
turbosol18's Avatar
Default Forever To build boost...??
I got a question..i finally finished my sohc vtec turbo setup and i went to go finally test drive it and i will floor it and it will go and go and i only get about 5psi around 7000rpm??? this is weird..
also i was testing some stuff out and on idle my dumptube is spitting out some exhaust?
Btw i am missing the O ring that goes in between the wastegate and manifold flange, could this be the reason why its leaking from the tube and also taking forever to spool up?
My setup is,
t3/t4 turbo 57 trim/ .63 A/R
FMIC 2.5 Intercooler pipe
3" open downpipe
tubular manifold
tial 38mm wastegate
Please let me know thanks
Old Aug 13, 2007 | 07:08 PM
needmypass's Avatar
Default Re: Forever To build boost...?? (turbosol18)
YES
Old Aug 13, 2007 | 07:16 PM
NJIN BUILDR's Avatar
Default Re: Forever To build boost...?? (needmypass)
x2
Old Aug 13, 2007 | 07:20 PM
Dyno247's Avatar
Yup, i had the same problem with my car. Until i realized that I didnt put in the valve seat in (the part your missing). The wastegate isnt suppose to be open at idle. By putting in the valve seat, that should fix all your problems.
Old Aug 13, 2007 | 07:27 PM
turbosol18's Avatar
Default Re: Forever To build boost...?? (Dyno247)
phew, im glad i was right...now heres the worst part of all,
Where can i find that valve seat?
Old Aug 13, 2007 | 08:09 PM
Schister66's Avatar
Man U FTW
its called a fire ring...you can order them from Tial i believe...if you can't find one, i think i may have an extra new one...pm me
Old Aug 13, 2007 | 08:39 PM
Dyno247's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">its called a fire ring...you can order them from Tial i believe...if you can't find one, i think i may have an extra new one...pm me</TD></TR></TABLE>
I heard other, but whatever floats your boat.
http://cgi.ebay.com/ebaymotors...ZWD1V
Old Aug 13, 2007 | 08:59 PM
needmypass's Avatar
Default Re: (Dyno247)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dyno247 &raquo;</TD></TR><TR><TD CLASS="quote">I heard other, but whatever floats your boat.
http://cgi.ebay.com/ebaymotors...ZWD1V</TD></TR></TABLE>
NO! it's called a FIRE RING. lol
sitinduk
Aug 4, 2017 02:18 PM
My_EFsedan
Aug 9, 2010 12:16 PM
craig88crx
Mar 17, 2010 07:38 AM
TheWhiteHatchProject
Jun 5, 2008 04:25 PM
oxSLEEPERxo
Jan 7, 2005 05:33 PM
