oil lines for turbo
Old Aug 12, 2007 | 09:50 PM
helpmycivic's Avatar
Default oil lines for turbo
hey guys im about to turbo my gsr ek coupe. im just wondering how i run the oil lines? do i tap the pan for the feed and return lines or do i pull the feed from somewhere else? if anyone could please help me out on this i would appreciate it. thanks.
Old Aug 12, 2007 | 11:33 PM
RCautoworks's Avatar
Default Re: oil lines for turbo (helpmycivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by helpmycivic &raquo;</TD></TR><TR><TD CLASS="quote">hey guys im about to turbo my gsr ek coupe. im just wondering how i run the oil lines? do i tap the pan for the feed and return lines or do i pull the feed from somewhere else? if anyone could please help me out on this i would appreciate it. thanks.</TD></TR></TABLE>
As for the oil feed, you want to run it off the back of the block, on a t fitting.
Old Aug 13, 2007 | 10:03 AM
Default Re: oil lines for turbo (RCautoworks)
ok well where off the back of the block do i have to put the t fitting? a pic would help out alot too. this is my firts turbo setup so im just trying to make sure i get it done corectly. thanks
Old Aug 13, 2007 | 10:11 AM
bigbadboy's Avatar
get a stealth oil line kit. don't put a T on the block cause its a bad idea. but ur oil is coming from where ur stock oil press. sensor is
Old Aug 13, 2007 | 10:15 AM
EG civic's Avatar
From the stock oil pressure sensor to the left of the oil filter on the back. You could also buy a Vtec conversion that would normally be used to supply the head but instead use it to supply the turbo. Also make sure when you tap the pan for the return mount it higher than the oil level, you dont want it to low otherwise it could back up the oil and ruin your turbo.
Old Aug 13, 2007 | 10:18 AM
MeanGreenMachine's Avatar
Default Re: oil lines for turbo (EG civic)
you could run the golden eagle oil sandwich adapter.....if you wanted too...
Old Aug 13, 2007 | 10:24 AM
EG civic's Avatar
Default Re: oil lines for turbo (MeanGreenMachine)
^^ Yes that is the the piece i was refferring too, but didnt state it.
Old Aug 13, 2007 | 10:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG civic &raquo;</TD></TR><TR><TD CLASS="quote">^^ Yes that is the the piece i was refferring too, but didnt state it.</TD></TR></TABLE>
im thinking about running one....but im going to do some more intensive and thorough research before purchasing
Old Aug 13, 2007 | 10:40 AM
Default Re: (bigbadboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy &raquo;</TD></TR><TR><TD CLASS="quote">get a stealth oil line kit. don't put a T on the block cause its a bad idea. but ur oil is coming from where ur stock oil press. sensor is</TD></TR></TABLE>
You do realize the stealth mode kit comes with the T right.
I'm not knocking the stealthmode kit, thats all we use here, even stock them on our website.
Old Aug 13, 2007 | 10:48 AM
EG civic's Avatar
Default Re: (RCautoworks)
Can you explain why its a bad idea?
Old Aug 13, 2007 | 10:50 AM
bigbadboy's Avatar
cause i see them break all the time and u end up squirting oil all the time. yea i know the stealt kit comes with a T. but u run a fitting off the block with a line on it to the T then from the T to the turbo. my t is at the fire wall
Old Aug 13, 2007 | 10:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy &raquo;</TD></TR><TR><TD CLASS="quote">cause i see them break all the time and u end up squirting oil all the time. yea i know the stealt kit comes with a T. but u run a fitting off the block with a line on it to the T then from the T to the turbo. my t is at the fire wall</TD></TR></TABLE>
The only time I have seen or heard a T breaking is when people put an after market sending unit hanging off the block. Like I said, we have used countless kits from stealthmode and never had an issue with them breaking. I understand what you mean, but if you look at the T he supply's, its pretty beefy from the threads to the actually T.
Old Aug 13, 2007 | 11:01 AM
Flamenco-T's Avatar
Teh only reason why yoru oil pressure sensor hole will break is because the wrong thread that was put in.
When you try to screw an NPT fitting in a BSPT threads, it will cross thread and eventually create a leak and break.
This is why we used BSPT adapter on all of our kit. I have never heard any problem with our kit breaking the oil pressure sensor hole and we have sold 5000 kits plus..
Here's the direction on installing our kit..
http://fast-turbo.com/images/p...n.pdf
Old Aug 13, 2007 | 12:42 PM
Schister66's Avatar
Man U FTW
the reason the block T fitting is somewhat frowned upon is due to a few people breaking fittings off in the block...if you're careful, you wont have a problem. There are enough people using these oil lines w/o any issues....i have them on my car
Old Aug 13, 2007 | 01:55 PM
stealthmode62's Avatar
Default Re: (Schister66)
Instructions: http://www.stealthmodeperforma...shtml
Old Aug 13, 2007 | 07:49 PM
thanks for all the good info and install instructions. i think ive got it all figured out. if i need any more help i will let you guys know. again thanks alot to everyone.
91accordexr
Dec 29, 2013 12:55 AM
boostitalready
Sep 6, 2012 04:57 PM
boriquabdygurl
Feb 18, 2007 07:04 AM
nsxblueteg
Jun 10, 2003 11:08 AM
iperez
Jan 18, 2003 04:36 PM
