so confused
Old Aug 16, 2007 | 01:57 PM
civic16's Avatar
Default so confused
ok, i was driving down the street and my traction bar hit one of those man whole sewage things, it was a hard hit. i started to leak a little coolant from the radiator and the car started to run horrible. it sounded like it was only running on 2 cylinders or something. i checked timing and its all fine, plugs are fine. there are no other leaks beside the coolant from the raditor. its a 1990 hatch, boosted b16. any help or input would be great.
Old Aug 16, 2007 | 03:38 PM
civic16's Avatar
Default Re: so confused (civic16)
help
Old Aug 17, 2007 | 12:16 AM
civic16's Avatar
bump
Old Aug 17, 2007 | 02:12 AM
SD_Lurker's Avatar
HT White Ops
Its really hard to say what it could be. When you hit the traction bar did the car immediately there after start running like **** or did it start to run like **** a few days later? Are you sure you didn't lose coolant and overheat causing your headgasket to go? Maybe its just a coinsidence that your car just started to run like pooh. I dunno some more details might help thats for sure.
Old Aug 17, 2007 | 08:36 AM
civic16's Avatar
Default Re: so confused (SD_Lurker)
ya, when it hit it started to run horribley right away. i didnt loose that much coolant, and i made sure to watch the temp gauge the whole way home, it didnt go above the half.
Old Aug 17, 2007 | 09:27 AM
civic16's Avatar
did a compression check today, from left to right
90 110 150 170.
any ideas?
Old Aug 17, 2007 | 11:09 AM
OLD_HATCH's Avatar
blown head gasket between the 90-110 psi cylinders???
Old Aug 17, 2007 | 04:11 PM
civic16's Avatar
Default Re: (OLD_HATCH)
ya but hitting a bump like that shouldnt just cause the head gasket to blow.
im stumped so far...
Old Aug 17, 2007 | 04:46 PM
spoolin hatch's Avatar
Default Re: (civic16)
Did coolant get on your dizzy that can cause a miss.
Old Aug 17, 2007 | 05:23 PM
civic16's Avatar
Default Re: (spoolin hatch)
i dont think anything did, the radiator broke at the very bottom, just a slight crack. i really dont want to do a headgasket if that isnt the problem, so any input on this would be great.
Old Aug 17, 2007 | 05:41 PM
HamiltonRex's Avatar
your compression numbers are bad, do a leakdown test see where the problem is.
I doubt its your headgasket, sounds like an ignition problem, hard hits and bangs cant often knock things loose.
Old Aug 17, 2007 | 06:38 PM
Blackturboteg's Avatar
Default Re: (HamiltonRex)
I agree number on the test don't look good at all. Sounds like it could be a headgasket.Or something else if its making really bad noises especially stop driving it if u already havent and time to tear it apart hitting that did something bad . Even if u messed up ur radiator doesn't mean something else didn't happen at the same time.
Old Aug 18, 2007 | 10:31 AM
civic16's Avatar
Default Re: (Blackturboteg)
ya we are doing a headgasket today and then checking everything n anything .
Old Aug 18, 2007 | 12:26 PM
civic16's Avatar
got the head off n the head gasket looks fine :/ cylinder walls look great n valves look good. what could be causing the low compression?
Old Aug 18, 2007 | 02:14 PM
jchrm80's Avatar
did your intercooler couple come off? seems to odvious but just throwing that out...
JDMJAYDC2
Apr 23, 2007 08:44 AM
broski
Jun 24, 2006 04:38 AM
SOHC_MShue
Apr 16, 2005 02:42 PM
Imadreamer1226
Aug 20, 2003 08:28 PM
AMChev
Sep 26, 2002 10:08 AM
