fuel pump help
Old Aug 12, 2007 | 09:16 PM
tony413's Avatar
Default fuel pump help
im having some troubles comparing fuel flow for two pumps
1. Aeromotive A1000 = 600 lbs./hour @ 45psi an 13.5 volts
2. Bosch 044 = 300LPH or 488 lbs./min @ 72.5psi an 12 volts
maybe im doing something right but would the bosch have a better than the Aeromotive ? the pump is going on a car that is a DD an the pump needs to support 650WHP. theres almost NO info on the bosch units ; also is the bosch 044 a pull type pump or push type pump ?
Old Aug 13, 2007 | 05:58 AM
tony413's Avatar
still looking for an answer
Old Aug 13, 2007 | 11:10 AM
Flamenco-T's Avatar
Default Re: (tony413)
The Bosch is the pull type, it can pull fuel eventhough it is located higher than the feul source.
This is the reason why we sell the bosch 10:1 versus the aeromotive.
The bsoch can be run using the stock intake fuel tank cover under your back seat, while the Aeromotive have to have a sump in order to work. Then by them time you mount the aeromotive LOWER than the sump, your aeromotive will sits about 1-2" from the ground.
This is typically where our customers install the bosch.
stan
Old Aug 13, 2007 | 12:22 PM
tony413's Avatar
thanks alot stan exact the info i needed but one more thing which one out of the two is going to flow more fuel or is the bosch able to support around 650Whp
Old Aug 13, 2007 | 12:39 PM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">thanks alot stan exact the info i needed but one more thing which one out of the two is going to flow more fuel or is the bosch able to support around 650Whp </TD></TR></TABLE>
YES, we used the bosch on the upwards of 700 whp ish.
The very last time my car was running we made 680 at 25 psi with a single bosch and 1600 cc injectors with a lot left in it.
PM me if you want to get the bosch.
stan
Old Aug 13, 2007 | 12:43 PM
Schister66's Avatar
Man U FTW
even though they're spendy, i've heard a lot of good from the Aeromotive A1000
Old Aug 13, 2007 | 12:54 PM
twkdCD595's Avatar
Default Re:
sweet, thats a conduit clamp (aka... a minnie) holding the bosch pump in the picture... sorry brain fart.
back on topic.
Old Aug 13, 2007 | 01:00 PM
tony413's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">even though they're spendy, i've heard a lot of good from the Aeromotive A1000</TD></TR></TABLE>
yeah i have used the Aero A1000 before an i know what it can do plus i got mine around $290 N.I.B. from a local company PM if you want the website. im just looking to try something different and i seen a few bosch 044's for around the $200-$260 mark for my LS build-up
corrupt0r
Welding / Fabrication
14
Sep 16, 2007 09:16 AM
EGJDM
Sep 21, 2004 07:02 PM
prelude994e
Sep 13, 2004 11:23 AM
VspecSiR
May 17, 2004 04:37 AM
